Hey all, with the extractors that you place on your car what do they actually do like in performance wise because i have been told many stories about that they dont do much or they dont do anything and like they give you heaps of power and stuff like that but i am unsure of what it actually does.? thanx
https://www.sau.com.au/forums/topic/50705-extractors/
  • Replies 40
I have yet to fit mine as im still saving up a bit of $$ to get them ceramic coated (not to mention find someone who does ceramic coating) But once fitting extractors, your power figure may not jump up, but a lot meatier, more useable band of torque through the lower-midrange of the power delivery should be expected.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1007457
i didnt find a huge increase in power uptop when i got my extractors fitted, but the power in mid range was increased 10 fold. It makes the car so much more fun to drive and gives it alot nicer crispier exhaust not, u wont be dissapointed. If i was ever to buy another NA car extractors would be the first mod i did to it.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1007498
i find my mandrel bent fujitsubo's to be a godsend...
a) the car revs a lot better, not as restricted as a standard manifold
B) makes the exhaust note really good (not so good when you don't have a resonator)
c) looks really nice under the bonnet when they're stainless steel :)
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1007540
A guy I know got a 13 rwkw gain when he got extractors and a 2 1/2" exhaust system on his R34 .
I have extracors and 2 1/2" exhaust system, on my R33 GTS25. I would totally recommend them, the car pulls very well through mid range and keeps pulling till red line.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1008785
  • 8 months later...
Hey guys looking at getting a set of hurricane extractors, just wondering if anyone on here has them? And if so what are they like?
RB25DE EXTRACTORS NEEDED .
Hurricane extractors , hmm , haven,t heard of them . do you have pics or where you can get them .
Also the fujitsubo extractors anybody know where you can get them or at least a pic of them
I modified a set of rb30e extractors to fit , but would prefer bigger primaries .
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1368911
Yeah when i was fixing my exhaust i got them to check one last time for any extractors other than Coby and they found a place in Sydney that does RB25DE extractors by Hurricane. I've heard of the brand just havn't seen a pic and don't knwo anythign about them. I wasn't expecting anyone else to do extractors for non-turbo's. Obvioulsy they're mild steel but i'll find out a little more about them.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1369769
i ddint realise the rb30 extractors could be modified to fit the rb25de. Any pics? How easy was it to do dondesoto??
Cheers
Paul
not a real simple fix
went to an exhaust shop and they profile cut some new flanges useing the cast iron rb25de manifold as a template
then i fitted the flanges to the head to align to ports
put flat washers on the manifold studs then tack welded the flat washers to the flanges . that way your flanges are aligned as best as possible . at this stage i ported the flanges to match perfectly to the heads ports .
i then cut the flanges off the rb30e extractors .
to get the pipes to line up with the flanges , i had to cut the secondary pipe that is fed by the 3 front cyls then rejoin .
tack welded the pipes to the flanges
removed extractors from engine and welded it all back together .
now if i had my camera i would do some pics , but its not here so if you are still interested i,ll post some later ( there are 2 pics of my engines in my profile but dont show exhaust very clearly )
much easier to buy a manufactured set , but i allready had the rb30e extractors from the previous engine
the local exhaust shop was willing to make me a set for $650 , another place called Gonzo pipes said $ 900 but people tell me he is the best
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1371076
the snakes help heaps ! trust me ! my old rb25de had a set of killer genie snakes on her, a quality simota air filter on it & a turbo muffler and the turbo boys used to have no chance !
my mates dad had a r33gtst that was boosted to 2 bar and over the first like 300 metres i had him cold !
for the measy outlay of $739 fitted, it really gives you a kick in the pants as opposed to one with standard exhaust.
Gotta fly guys, got turbo butts to kick !
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1389739
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
