Hey all, with the extractors that you place on your car what do they actually do like in performance wise because i have been told many stories about that they dont do much or they dont do anything and like they give you heaps of power and stuff like that but i am unsure of what it actually does.? thanx
https://www.sau.com.au/forums/topic/50705-extractors/
  • Replies 40
I have yet to fit mine as im still saving up a bit of $$ to get them ceramic coated (not to mention find someone who does ceramic coating) But once fitting extractors, your power figure may not jump up, but a lot meatier, more useable band of torque through the lower-midrange of the power delivery should be expected.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1007457
i didnt find a huge increase in power uptop when i got my extractors fitted, but the power in mid range was increased 10 fold. It makes the car so much more fun to drive and gives it alot nicer crispier exhaust not, u wont be dissapointed. If i was ever to buy another NA car extractors would be the first mod i did to it.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1007498
i find my mandrel bent fujitsubo's to be a godsend...
a) the car revs a lot better, not as restricted as a standard manifold
B) makes the exhaust note really good (not so good when you don't have a resonator)
c) looks really nice under the bonnet when they're stainless steel :)
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1007540
A guy I know got a 13 rwkw gain when he got extractors and a 2 1/2" exhaust system on his R34 .
I have extracors and 2 1/2" exhaust system, on my R33 GTS25. I would totally recommend them, the car pulls very well through mid range and keeps pulling till red line.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1008785
  • 8 months later...
Hey guys looking at getting a set of hurricane extractors, just wondering if anyone on here has them? And if so what are they like?
RB25DE EXTRACTORS NEEDED .
Hurricane extractors , hmm , haven,t heard of them . do you have pics or where you can get them .
Also the fujitsubo extractors anybody know where you can get them or at least a pic of them
I modified a set of rb30e extractors to fit , but would prefer bigger primaries .
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1368911
Yeah when i was fixing my exhaust i got them to check one last time for any extractors other than Coby and they found a place in Sydney that does RB25DE extractors by Hurricane. I've heard of the brand just havn't seen a pic and don't knwo anythign about them. I wasn't expecting anyone else to do extractors for non-turbo's. Obvioulsy they're mild steel but i'll find out a little more about them.
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1369769
i ddint realise the rb30 extractors could be modified to fit the rb25de. Any pics? How easy was it to do dondesoto??
Cheers
Paul
not a real simple fix
went to an exhaust shop and they profile cut some new flanges useing the cast iron rb25de manifold as a template
then i fitted the flanges to the head to align to ports
put flat washers on the manifold studs then tack welded the flat washers to the flanges . that way your flanges are aligned as best as possible . at this stage i ported the flanges to match perfectly to the heads ports .
i then cut the flanges off the rb30e extractors .
to get the pipes to line up with the flanges , i had to cut the secondary pipe that is fed by the 3 front cyls then rejoin .
tack welded the pipes to the flanges
removed extractors from engine and welded it all back together .
now if i had my camera i would do some pics , but its not here so if you are still interested i,ll post some later ( there are 2 pics of my engines in my profile but dont show exhaust very clearly )
much easier to buy a manufactured set , but i allready had the rb30e extractors from the previous engine
the local exhaust shop was willing to make me a set for $650 , another place called Gonzo pipes said $ 900 but people tell me he is the best
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1371076
the snakes help heaps ! trust me ! my old rb25de had a set of killer genie snakes on her, a quality simota air filter on it & a turbo muffler and the turbo boys used to have no chance !
my mates dad had a r33gtst that was boosted to 2 bar and over the first like 300 metres i had him cold !
for the measy outlay of $739 fitted, it really gives you a kick in the pants as opposed to one with standard exhaust.
Gotta fly guys, got turbo butts to kick !
https://www.sau.com.au/forums/topic/50705-extractors/#findComment-1389739
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
