  • Replies 40
Does anybody know where i can get my hands on a set of extractors for a rb20de Cefiro, around the brisbane area.
Looking to get fitted too.
So the one joint to do both would be good.
i havent been able to find anybody who sells rb--de extractors in brisbane , but had a quote of , i think it was $650 , to have a set made at Rob Bliss exhaust @ Geebung
IM STIL 16, I JSUT BROUGHT A SKYLINE R33. WILL EXTRACTORS MAKE A SOUND DIFFERENCE TO THE SKYLINES? OR DO THEY ONLY BENEFIT TO PERFORMANCE.
CHEERS
ERAN
if u want so make ur skyline sound better than remove any mufflers u have installed in ur pipe and get a bigger rear end muffler, in other words a cannon
I agree, i have 2 1/2" cat back with cannon. sounds sweet. lovely vibrations throughout the car.
needed to turn the stereo up for some reason though. :looney:
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
