  • Replies 40
i got a set of coby extractors suit RB20/25 FS if anyone wants em :D
IM STIL 16, I JSUT BROUGHT A SKYLINE R33. WILL EXTRACTORS MAKE A SOUND DIFFERENCE TO THE SKYLINES? OR DO THEY ONLY BENEFIT TO PERFORMANCE.
CHEERS
ERAN
Does anybody know where i can get my hands on a set of extractors for a rb20de Cefiro, around the brisbane area.
Looking to get fitted too.
So the one joint to do both would be good.
i havent been able to find anybody who sells rb--de extractors in brisbane , but had a quote of , i think it was $650 , to have a set made at Rob Bliss exhaust @ Geebung
CHEERS
ERAN
if u want so make ur skyline sound better than remove any mufflers u have installed in ur pipe and get a bigger rear end muffler, in other words a cannon
I agree, i have 2 1/2" cat back with cannon. sounds sweet. lovely vibrations throughout the car.
needed to turn the stereo up for some reason though. :looney:
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
