hmmm does anyone know if Type R integras pull hard? my mate said he nearly got done by one and he has a R33 gts-t.  The integra was the new model one. (with the copy cat skyline lights at the back)
the new type R's will give any stock 33gtst a run for their money. i was just under a car length ahead in mine till i put it in third and we stopped there at 80. was no point goin any faster on public roads and we had fun even though it lasted a couple secs. much respect to the new type R.
  • Replies 55
AWD is available in the US and kicks most nissan and other  :Oops: butt.
Hey, I own a Starion as well. :D
contray to popular belief overseas..
the DSM cars are not all what they would appear to be.
sure, they have 4WD and a turbo inline 4 based off the 4G63.
and unless you get a turbo upgrade (which can cost thousands here) your DSM is not going anywhere. true, lots of boost on the stock turbine is good too, but it can only take the car so far. the size of the turbo is what i'd call tiny (with the housing, it's only about as big as a CD). on a side note, the 2nd gen DSM uses a T25 turbine.
the engines also have their fair share of problems, mainly crankwalk (which occurs in 2nd generation DSMs). crankwalk is when the crankshaft moves out of place naturally, perhaps due to an engineering miscalculation ? this basically renders the engine as junk.
i don't have much faith in these cars, they're ugly, they've been riced out, and they're heavy as $#*$ too. it'll pull on me in a 1/4mile, but from a rolling start; it doesn't stand a chance. my friend's EG civic with a b16a(cable clutch version too)with bolt-ons can outrun an equivalently modified Eclipse GSX (turbo 4wd model) from a rolling start.
(on a side note, i think i would've rather had chosen the FTO GPX over the Eagle Talon/Mistubishi Eclipse...but then again, on paper, it looks very much like a Honda Prelude with a 2000cc V6 as opposed the Prelude's 2200cc inline 4.....and good god, don't even talk about Preludes)
and on a side note:
i haven't driven, let alone even seen a Skyline or FTO in my life..but, i already know the easiest answer to the thread starter..you got burned, simply because the FTO had an advantage over you:
-less weight (still less than you and your sister...even when he has a full car load)
-doesn't the FTO rev higher...i remember seeing somewhere online that it peaks right before 8000rpm
-it was probably heavily modified, i've seen/met up with plenty of cars like that in Canada....you think they're slow, then they show their true potential (stock looking MKIII Supra turbo making 630rwhp) and it leaves you scratching your head...or at least feeling like an idiot for even trying to race.
Man i don't know why all your N/a are so slow.
ive got a 1994 GTS25 5 speed, all that i have done to it is K&N filter, when i got it, it had a exhaust and thats all that i know of. no extractors. its got 4ws and a LSD.
and i am yet to loose a race to a V6 commodore or falcon.
ive raced 3 r32 GTS-t got to about 120km/h and i was 1 1/2 car lenghts in front of them.
raced a 5L VN Calais with extractors and exhaust and left him about 1 car lenght behind me as soon as i got out of second.
ive raced a BA XR6 N/A same as above.
on a cold day me car does 0-100km/h in anywhere form 6.5- 6.9 seconds. thats if i change gears on time.
Pffft I could take Falcodores in my Twincam Corolla.
The R32 GTS-t's must have been piloted by corpses if you beat them.
BA XR6...too fat and slow to even try to be fast.
The only waty your gts could keep up with a V6 commodore if the commodore wasnt even trying. There is no way in hell that you could beat a R32 gts-t in a gts. In your dreams it doesnt count.
and you probably measured your 0-100 on a timer that stops at 6 seconds and couldnt go any further.
:bs!:
give me a couple of months krzysiu, and I'll kick your skanky ass in my R32 GTS :cheers: (never mind the RB25DET and the TD06 25G that's sitting under the bonnet)
and kaz141, mate grow up and stop racing old people on the street... :D
mate own a EK4 with full exhaust (4-1 mainfold, high flow cat, cannon exhaust) and run 16" TE37.
I run him a while ago and suprise me how quick a N/A 1.6 car can be.
rolling start in second and at the time i change into 3 he still manage to keep his car in about 1 car lengh behind.
i "think" it will eat the FTO & N/A gts.
sure the type R is even better.
The Jap spec new Type R (DC5R) is faster than DC2R in both straight line and track
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
