Hi
Well i said in some threads in discussion to SAFCII's i was getting mine tuned... Well i did today so here are my cars performance mods and the results!
r33 GTS25T 95' Series I.5
T3/T4 HighFlow VL Turbo
GTR Front Mount Intercooler
GTR Fuel Pump
Apexi S-AFCII
GReddy Profec B Boost Controller
3" Exhaust Turbo Back
HighFlow Cat
MegaFlow Muffler Twin 2" Tip
K & N Pod Filter
Blitz Open-Atmosphere BOV
Brass Button Clutch
Locked Diff
9.5" Wide Rear Works Rims
Always run 98 Octane
Stock RB25DET engine.
Stock Headgasket, Injectors
For anyone interested i hope this is enough information to show a power example for these mods and turbo. The tuner said they had a another t3/t4 on another car and it only made the same power on 18 psi, they said they were happy with the result on 12psi and i was too.
Oww i was running Optimax too so once i run Ultimate into it im getting a free Retune in about 2 weeks so we'll see the difference in power there too! BP vs Shell in the ultimate showdown! Bring IT ONNNN!
Cheers,
https://www.sau.com.au/forums/topic/50725-safcii-dyno-tuning-results/
Care to post up your SAFC2 settings?
 Purely for interest's sake?  I'd love to compare them to my tune...
Well depending exactly on how your car runs it'll be tuned accordingly.. i had a quick look... and fuel was leaned out. I cant post up the setting exactly, theres lots of adjustments, + its not like i can do a "Print Screen" sorry.
Cheers,
Very nice result mate! 218kw at the rears is amazing!
Where did you pick up the SAFC-II from? I'm trying to find a cheap outlet.
Came with the car sorry... I would have thought there'd be a few for sale on the 'For Sale' posts when people dictch them for Power FCs. Probably just check Nengun, nismo.com.au, modyourcar.com.au *i think*, and yeh do some searching... Good luck with it.
Cheers,
Thats a pretty impressive gain, you using the stock AFM as well?
I've just fitted one to my stock RB25 with FMIC and pod filter all else stock, I've had a fiddle around with it (small amounts of leaning out) and cant reeaaalllly tell any difference using the "seat-of-pants-o-meter".
I dont wanna muck around with it too much, but i'd like some idea of what ppl's safc's are set to roughly, as far as % correction at what rpm etc? how rich do these things run?
Thanks the sphincter of the universe, remember the Turbo is doing a lot of that gain and not just the SAFCII, they work well with each other. As for tuning, i highly recommend you take it to a dyno tuners... There is lots of little adjustments to get it just right... $250 seems to be a pretty standard rate and they might spend a few hours doing it. You should get a more than happy gain with your current mods, you should really get a boost controller too. I'd get that first, then they'll tune it to your new higher boost! More rwkw! :mad:
Cheers,
good work!! its always good to see results from a tuning session. You'd be surprised the difference fuel makes. Originally had mine tuned on optimax, then switched to Synergy8000, an now runs much better, cleaner, less smell, an more power. From what I hear on both here on the forums and from tuners, so long as you stick with either Synergy or Ultimate your pretty set.
Anyway, good luck with the next tune, keep us posted.
fuel cut defender, adj fuel reg, more boost.....go a long long way :mad:
cheers
Yup mine cost $100 to get tuned. The guy did literally did it in 5 minutes, 1 power run, tweak, another power run, tweak, final power run. Money please!
Kinda dissapointed me in the BFYB terms haha But the gains were solid...
Well i got to test out my new power this afternoon taking it to some good local roads *yesterday was wet* & i was VERY happy with the power... Shit! 3rd is pulling like a mutha f***a :D & theres wheel spin all the way though 2nd now.. yeh she's got some power going now... Might be able to do high 12's but I haven’t been to a drag yet so who knows. Anyway... just letting ya know 218 at the rear is not to shabby to drive at all.. .lots of fun :) and makes drifting that much easier...
Get the SAFC tuned on a dyno, you can even do it yourself, i do. With the stock cooler i was pulling 18% of fuel out at the top end, but with the installation of the FMIC, its now down to about -12% at the top end.
and how did you figure this out? I'm shit scared of making her detonate. My approach was to lean out gradually then swith to the knock monitor, but surely thats dodgy? besides its hard to tell what knock reading is bad, it sits around 40 or 50 normally i think but will sometimes hit 200. I cant wait to get mine on the dyno now, just gotta get new pump in.
  • 4 weeks later...
I am interested to know this standard knock as well...
The only time i get any knock figures showing on the SAFCII is when its warm and idling. It shows upto 5 sometimes...Whatever that means?
Mine got installed and tuned yesterday 194kw's. With FMIC and K&N Pod. On 12psi.
I'm not sure how much its leaning out.
Also, this morning im experiencing problems with idle when cold now. (only since the SAFC was installed).
It doesnt kick the idle up to the 1200 or so that it did when the car is cold. It was struggling to even stay running, spitting and coughing actually.
I couldnt even get it to hold a steady 1100rpm idle by using the accelerator?? It would just peak to 2000 then back to 600...Once it was warm the throttle responded as per normal??
Weird.
Weird.
Hi, the current model of SAFC11 has two throttle position programs, they are programable, but usually set with one for under 70% and one for over 70%. It would seem that your tuner has only tuned for over 70%. If he uses the under 70% range he can tune at the low rpm ranges to fix that problem. This will not affect over 70% throttle settings or high rpm.
Hope that helps:cheers:
Does that also mean that I wont actually notice any difference with fuel consumption?
Cause my last tank of fuel I only got 250kms....(i was heavily strapping it) Plus it smells a little fuely on idle, so i wanted the safc to lean it out so it wasnt soooo rich.
That's what the 2 settings were developed for on the SAFC11's, so you could have power (large throttle openings) and fuel economy (small throttle openings). You couldn't do that with the previous models, you always had to choose one of the other.
Have a talk to your tuner, it is a pretty easy job to tune.:rant:
Im wondering what the majority of Skyline owners have got the air correction set to when on full open throttle?
From what I can tell mine is on 5.
I *think* I have heard that others have got theres on around 10??
Im yet to call the tuners and talk to them about my current problems, I wanted to have a better understanding before I call them. I did download the English manual for the SAFC2 though. Makes a lot more sense than the Jap one I was reading...LOL
Paul
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
