It time to get some new rubber on the beast.
At the moment Im running 225*45*17 all round.
(I think the wheel size is 17*7.5jj)
For some weird reason I suffer from a lack of traction at times...
Anyone got any recommendations on what size tyres to put on?
Would 245*40*17 all round be a decent choice?
or prehaps 245*40 at the rear and 225*45 at the front?
Or am I just better sticking with 225*45 all round?
https://www.sau.com.au/forums/topic/50735-tyre-size-recommendation-for-r34gtt/
I'd be very careful. Changes to the rolling diameter can affect the TCS adversely and think its constantly slipping. Now of course if you drive with it off its doesn't matter.
Thanks for that.
According to the book at the tyre dealer the difference in diameter between both sizes is 4mm. You get more difference than that between a new and worn tyre so it should be ok I guess.
Why wouldn't you put the widest tyres you can fit and afford?
You might have different width if your rear guards can hold wider than your front ones as they do on a GTT but with 7.5" wide rims you're not where near too wide so put the widest sensibly possible on there.
Ok, thanks.
That makes sense.
I assume that 245 is as wide as I should go on 7.5" rims?
Is there any particular reson to put the same width on front and back?
Ive seen a number of cars which are different from front to rear.
yeah the wider your tires on the front the more 'vague' the steering will feel.
ie. I wouldn't go over 235 wide on the front of my GTSt
Then again tyre brand and quality is more important than overall size for handling
245's will easily fit on 7.5" wide rims.
I am not sure if 255's would fit on 7.5" though?
But as Tony said 255 wide tyres fit on a skyline easily with no troubles.
I had 235 front and 255 rear before and it didn't bring up the slip light.
I'll be running 245 and 265 next month :)
Silly question maybe, but why would different sized tyres bring up the slip light?
Do you mean different sized front to rear ?(I could understand it, if they were different diameter), or just different sized from standar all round?
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
