Getting damn epa notice. ;)
Pulled over again 7:50am!! cruising down Hume Highway just near Wodonga going to work. Look up cop sitting on the median strip turning other direction. Look up again as i am turning off onto nice quiet backroad to find cop car positioned in usual liner hunting pose right up my arse. :bs!:
Pull into back road and straight over, procedes with usual rbt then comments that my car is too low (HKS fronts and temporary lowered nismo rears) and how his rbt straw is exactly 100mm yeah yeah. I reach in the glove box and show roadworthy completeted only this Monday.
Then makes open bonnet(first time in 2years of owning R33's), I get out he then has a quick glance inside. Comes over telling me he knows what he is looking whilst leaning one hand on very illegal bov after awhile says "what this" pointing to evc module (should have hidden that damn it). Keeps looking then pats the pod filter a couple of times
"you can close the bonnet now".
"Can you drive the car over there"
pointing to middle of the road f#@k me getting shitty now. Then MrPlod trys to climb underneath car with a straw after some dicking around comes up empty. "Open the bonnet" what the. Yes open it again. :D
Has another look asking me wot boost i'am running? "standard the unit is not tuned in to run any thing else". Spends another 5 min looking. Said nothing about bov, safc, boost guage, and would have not have chance of spotting a HKS2535. Tells me boost controller is not epa blah blah blah was just thinking of the time and $$$ to go back to standard. Is it possible for Vic cops to defect NSW reg car or send them for EPA??? i suspect with epa it might be.
https://www.sau.com.au/forums/topic/50818-evc-epaed/
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
