Hi All,
I have a pair of Garrett N1 turbos for sale, plus 6 * 600cc TOMEI injectors (top feed low impedence), suit GTR.
I was going to put them on *my* GTR but the missus busted me - lol, so this is a very, very regretful sale.
Turbos include HKS actuator arms, travelled 16k on R34 GTR. Proven for 600hp.
Injectors travelled 200km.
Please find a nice home for these.
Prices:
Garrett N1 turbos: $2950 Price drop
TOMEI 600cc injectors: SOLD
Photos below.
PM or email: [email protected]
Phone: 0402 064 179
Garrett N1 turbo spec:
Custom 0.60A/R Compressor Housing.
62 Trim Compressor Wheel (35lbs/min).
Custom 0.64 A/R Turbince Housing.
79 Trim Turbince Wheel.
Rated 350hp-400hp each turbo (650hp-700hp pair).
Direct bolt on units.
Very similar results to HKS 2530.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
