I was just wondering would anyone know if the HKS EVC4 will get rid of boost cut?
What car is it for? Do you mean your 180km/h speed limiter ? or stock boost? There is not "boost cut" but you may have a fuel cut out when boosting too high with stock ECU. The stock boost is set at a certain level, if u replace the solenoid with an aftermarket electronic boost controller... u can boost to what ever u want. Just make sure you increase your intake air cooling capacity before boosting above 0.7 bar
https://www.sau.com.au/forums/topic/50871-boost-cut/#findComment-1009112
and just to clear it up.  Does that mean that if i have an electronic boost controller with a different boost solenoid i would not need to get a fuel cut defender?
It's not your solenoid which controls the fuel cut... it's your ECU. Adding an aftermarket solenoid, bypassing your stock solenoid, and having an electronic boost controller will allow you to increase your boost, but the ECU will still cut fuel once you go above a certain level of boost because it thinks your engine is receiving too much fuel, but in reality you're running more boost which is making more power and burning fuel quicker. You will need a fuel cut defender if you're having fuel cut out issues, but I wouldnt recommend using a FCD if you're boosting above 1.0 bar. Get a Power FC, and make sure you have adequate cooling capacity as you increase power.
https://www.sau.com.au/forums/topic/50871-boost-cut/#findComment-1009137
Hi Chan, "Over boost protection" is what it is sometimes known as, but it is really "excessive airflow protection". The ecu makes this decision based on what the AFM is telling it. So boost really has nothing to do with it. The fix is an SAFC, voltage clamp, Boost Cut Defeater or better still replace the std ecu with a Power FC. Full fuel cut is the next step in engine protection programming in the ECU, but you get "retard" and "rich" first.
Here is a post I prepared earlier that may help
Hi guys, a quick, simplistic explanation of how an SAFC works might help...
As the airflow into the engine increase, the AFM records this as increased voltage that the ECU sees. What an SAFC does is sit in between the AFM and the ECU and take the voltages from the AFM and either increase or decrease them depending on what you have programmed the SAFC to do. By increasing the voltage, this tricks the ecu into pumping in more fuel, you do this when the engine is running lean. By decreasing the voltage, this tricks the ecu into pumping in less fuel, you do this when the engine is running rich.
The next bit is hard to understand unless you remember that the standard ecu does not supply fuel in direct proportion to the afm voltage ie; 4 volts is not twice as much fuel as 2 volts. Engine rpm, boost and throttle position also help the ecu determine how much fuel to add.
It has been my experience that RB25's run a little lean down low in the rpm range (Nissan do this for fuel economy and emissions) and a lot rich up high (Nissan do this to protect the engine). So I have to increase the voltage (using the SAFC) up to around 3,000 rpm (part throttle especially) and decrease the voltage over 5,000 rpm (full throttle).
The real problem is in the 3,000 to 5,000 rpm range as the engine comes on boost. They really need lots of fuel very quickly in this area. This can mean that you need to increase the voltage (that the ecu sees) over 5.1 volts to get the right A/F ratios. The ecu then goes into engine protection mode, rich and retarded (sounds like a girl I knew once) :boobies2: . Past that rpm you can start leaning it out as it runs too rich, so the voltage needs to be turned down under 5.1 volts. The ecu sees this as the engine not needing protection mode any more, no more rich and retarded.
It is not unusual to get good performance up to 3,000 rpm, then sluggish from 3,000 rpm to 5,000 rpm and then good performance from 5,000 rpm and over. The SAFC may not help this, in fact as explained above, it can in fact make it worse if the tuner is not switched on to this stuff.
With bent afm voltages, the ecu (tricked by the SAFC) also fires the ignition to suite the airflow it THINKS the engine is getting. This is not a good thing as you generally end up with ignition that is too far advanced in some rpm ranges.
The poor tuner has to juggle the SAFC settings, so that the A/F ratios are OK, the ecu doesn't get into rich and retard (engine protection) mode and the ignition timing is not too far advanced so as to cause detonation. My experience (I am not a good tuner) has been that this is full of compromises, sometimes you just can't win and have to reduce the boost level a bit to get even a reasonable compromise.
Keep in mind that this explanation is very simplified to make it fit in a reasonable space, the rpm's used are rough guides only and every car is different.
Hope it helps (and makes some sense). :D
https://www.sau.com.au/forums/topic/50871-boost-cut/#findComment-1009430
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
