Just thought i'd start a spotted cefiro thread. :)
Was driving along canley vale today (sat 11/09/04) and i see a black stock cefiro tailing me. If its one of you nsw guys on the forum. I gave him a wave and so did he.. Sothing about seeing other ceffys around. I can prtty much count the number of ceffys in sydney atm. This is the first NSW one ive seen in 3 months apart from nissaners one.
https://www.sau.com.au/forums/topic/50874-spotted/
  • Replies 215
Spotted: JIMMAH - Black Cefiro owned by Jimmah, and ENEMIE - White Cefiro owned by Adam. Both from WA and recently competed in the Drift Nats. Spotted yesterday at Collie for the G Speed Drift Day. Cefiros taking out 1st,2nd and 3rd positions! Clean sweap!
JK
https://www.sau.com.au/forums/topic/50874-spotted/#findComment-1010271
I rolld past a sweet looking black cef, with the plates CEFFIE or similar tonight on the way back from the gym, was parked on pacific highway near st leonards. Good to know there are other cefs on the north shore!! I slowed right down but no one was in the car so i kept going... is the owner on here?
https://www.sau.com.au/forums/topic/50874-spotted/#findComment-1014166
I saw that car in Norton St (Leichhardt) last week. Sounded pretty horn too :)
LW.
https://www.sau.com.au/forums/topic/50874-spotted/#findComment-1014413
HEHE that was me! i was doing a radio show at 2UE. :headspin:
I have seen a stock black one on parramatta road, i gave the dude a beep and he smiled. 20/8/04
I have also seen a white one with a RB20/5/6 hybrid that puts out 300orr rwkw. it looks kinda stock but the dude showed me under the bonnet and my jaw dropped. it was in leichhardt.10/9/04
we really need to do a sydney cefiro cruise. Are any of you guys going to the Initial Drift practice session this sunday?
https://www.sau.com.au/forums/topic/50874-spotted/#findComment-1015119
if any i syd boyz wann ceffy cruise count me in.
i pulled out of that one (initial drift day) bc im going raving the night b4. man u cant be peaking and driftiong at the same time. would spin u out or u could really hurt yourself. LOL
https://www.sau.com.au/forums/topic/50874-spotted/#findComment-1015306
Just thought i'd start a spotted cefiro thread.  :rofl:
that was me man
https://www.sau.com.au/forums/topic/50874-spotted/#findComment-1015328
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
