  • Replies 215
Grey/Olive cefiro with update tail lights, mesh rims otherwise stock with brown intirior
EEWWWW! spotted on glebe point road. and parramatta road 27/12/04
i am not going to count all the times i see all the guys from SAU.
saw James's car today and its funkin sweet and sounds like a beast mmmm rb25 cefiro goodness.
That would be mine yeh the brown interior really sucks!!!! its a genuine 1992 series II Ceffy imported in 1998 pre SEVS NA 5 speed Auto going RB25 early next year with a HKS gt2540 and cusco 2way lsd custom paint job. Using it as a promo
car as i am a co-owner of Ezzy-style motorspot www.ezzystyle.com.au
https://www.sau.com.au/forums/topic/50874-spotted/page/3/#findComment-1141517
3 weeks ago saw Riversides old 1 at BWCP aswell as Fidels.
On the M1 raced Riversides old 1 at DRF74 a white cefiro with worked rb20det.
Last night saw another Blue cefiro with white rims and RB26DETT(pssht copy my idea why dont ya :D) If only mine would of been running i'd of lined him up hehehe :)
https://www.sau.com.au/forums/topic/50874-spotted/page/3/#findComment-1142916
Yeah your front bar looks about right.
And yeah wasn't hooning - it was just too fast to look at closely :(
might've been me... (my gf lives in the city and i live in northshore.. i go past harbour bridge at least twice a day... :D )
although i don't remember driving too quick... (shhh... this is a public forum ;) )
https://www.sau.com.au/forums/topic/50874-spotted/page/3/#findComment-1144674
yeh we lined up NIZ-016 and went at it. Heard a nice Bang then a clunk clunk clunk. We think its the part from tailshaft into diff but wont know until we get car on the hoist and have a proper look.
more than likely the exact same thing that happend to mine...
was taking it out for testing and gave it a bit of a hard launch. I think cause of the increased power (which is even more so in ur case) and the fact the drive/tail shaft is slightly offset rather than straight it puts even more pressure on the mounts that hold it to the body... and theyre not exactly that solid and there arent that many of em... 2 bolts up into a metal plate.
we ended up fixing it and welding it up even better than when it left nissan :P and seeing as it withstood the punishment at banzai it obviously worked well :)
https://www.sau.com.au/forums/topic/50874-spotted/page/3/#findComment-1150388
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
