  • Replies 215
  • 3 weeks later...
ive seen 2 in kirrawee one with a massive kit on it looked amazing had some sort of sticker on the windscreen and the other was actually in my street it drove past my window sounded tuff had a rough idle wen it stopped and all i could hear wen it came past my house was the turbo spooling insane sounding didn get a real good look at it tho
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1210500
(quote) saw a very nice looking cefiro (white) with autech kits or something similar between 6-7pm on werona road near killara station. number plate was black on white... ASQxxx (quote)
that ceff is an animal. it has seem welded and riveted body.
and it has a rb24 stroker and puts out 250rwkw according to the guy who used to own it
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1210899
one of the ceffies from kirrawee could have been mine, its been at my mechanics there a bit lately, white and fairly loud intake noise..
and seen a stock tidy blue cefiro around sutherland a couple of times. but not in the last month. cant wait too see another around, only seen the one
anyway, hi:) (first post)
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211275
i met the new owner, Simon, tonight... very nice guy :) (he was nice enough to believe me that i had a cefiro when i was in a commodore tonight :P ) had a little chat after we pulled over.. his ceffy looks/sounds HOT :whackit:
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211749
saw two today:
one was brigth blue, cage, zaust, mild kit, drift rims with custom ceffy plate being driven by a chick on her way to school :P
second was a japanese drifter i met last night at the servo, fark me!!!!!!!!! im not saying too much about the car but damn this boy has got skills!
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211826
saw two today:
!!! Was she hot!?
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211893
I saw a black, Possibly gray Ceffie in emu plains near penriff last week, I almost mistook it for a silvia at first. Its the only one I have seen out west sydney
It had lots of shtickers on it - anyone know who's it is?
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1212683
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
