  • Replies 215
  • 3 weeks later...
ive seen 2 in kirrawee one with a massive kit on it looked amazing had some sort of sticker on the windscreen and the other was actually in my street it drove past my window sounded tuff had a rough idle wen it stopped and all i could hear wen it came past my house was the turbo spooling insane sounding didn get a real good look at it tho
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1210500
(quote) saw a very nice looking cefiro (white) with autech kits or something similar between 6-7pm on werona road near killara station. number plate was black on white... ASQxxx (quote)
that ceff is an animal. it has seem welded and riveted body.
and it has a rb24 stroker and puts out 250rwkw according to the guy who used to own it
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1210899
one of the ceffies from kirrawee could have been mine, its been at my mechanics there a bit lately, white and fairly loud intake noise..
and seen a stock tidy blue cefiro around sutherland a couple of times. but not in the last month. cant wait too see another around, only seen the one
anyway, hi:) (first post)
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211275
i met the new owner, Simon, tonight... very nice guy :) (he was nice enough to believe me that i had a cefiro when i was in a commodore tonight :P ) had a little chat after we pulled over.. his ceffy looks/sounds HOT :whackit:
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211749
saw two today:
one was brigth blue, cage, zaust, mild kit, drift rims with custom ceffy plate being driven by a chick on her way to school :P
second was a japanese drifter i met last night at the servo, fark me!!!!!!!!! im not saying too much about the car but damn this boy has got skills!
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211826
saw two today:
!!! Was she hot!?
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1211893
I saw a black, Possibly gray Ceffie in emu plains near penriff last week, I almost mistook it for a silvia at first. Its the only one I have seen out west sydney
It had lots of shtickers on it - anyone know who's it is?
https://www.sau.com.au/forums/topic/50874-spotted/page/4/#findComment-1212683
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
