  • Replies 90
1) Make sure you have Jap english support on your operating system. Some of the files are in Jap and won't be able to uncompress if you don't have it enabled (Start>settings>control panel>regional and language settings>or something like that)
2) Copy the maps (you can only play with the maps until you get the cable) into a seperate directory. Right click on the directory with the executable and go down to properties. Insert a Japanese character (any will do, try this ススカイライン) into the directory name.
The cable is a complicated device (well, to a layman like me it is) and will require a bit of work. More on that tomorrow, just download the stuff and host it before I get torched and have to remove it.
https://www.sau.com.au/forums/topic/50883-powerfc-software/#findComment-1009321
Doughboy... can't help but feeling that the first post was directed at me... :D hehe. I haven't as yet replied to any of the PM's I got about the power FC software, but I was gonna charge somewhere around $20 for a copy.
aaaaanyway seeing as you've got the software (well... part of it, there's other revisions as well that work with different PFC's) you will no doubt have the instuctions on how to make the cable. I have the instructions as well, but am having some trouble sourcing some parts to make the cable, specifically the NEC reprogrammer that you need to flash the PFC with so you can use a non proprietory cable to communicate with it. Total cost of the cable itself should be around $250 to make. Thoughts, ideas?
https://www.sau.com.au/forums/topic/50883-powerfc-software/#findComment-1009372
This is great guys, I'll be in for a group buy if it will help with cable pricing. (I also have access to trade priced at a few IT and electrical places if it is of use to anyone)
PS - I have looked at the software a few times now but I cant find the setting for "WARNING MANIFOLD PRESSURE TOO HIGH" or the "DROP PASSENGERS FLOOR PAN - sparks set to 85%" activation settings.
https://www.sau.com.au/forums/topic/50883-powerfc-software/#findComment-1009524
...Let the engine torchings begin! lol :D
LOL... what do you know about tuning, anything you can do i can do better...provided the aim is to throw a rod thru the drivers window of the car alongside you, i bet i can mix it with the best :headspin:
Oh, and leaner mixtiures means more power right? :Bang:
https://www.sau.com.au/forums/topic/50883-powerfc-software/#findComment-1009536
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
