Yesterday I install a brand new Hybrid FMIC to my r33 gtst.
about 12 months ago I had a SAFC installed and tuned as I had flat spots (running to rich) the SAFC fixed that problem.
I had being running 10psi before the cooler was installed but now I cant run anymore than 7 or the car seems mess and cough under load. I think this may be due to incorrect setting on my SAFC because now im getting so much more cool air. Do you need to get your SAFC retuned after the installation FMIC? Or am I on the wrong track what else could cause this?
https://www.sau.com.au/forums/topic/50907-problems-after-installing-new-fmic/
Using a FMIC will mean cooler inlet temps, so your SAFC may need a touch up tune.
Although the coughing and missing sounds like a spark plug issue.
Do you know what type of plugs you have and what size gap they are ?
J
Plugs are near brand new gapped at 0.8. pretty sure its no thats not the problem because the car was fine before the cooler went on. its hard to explain but the car is no realy missing its more of a hesatation might be a boost cut or something?
Your SAFC will need to be redone but i shouldnt have thought it would make it spluttery. When i done mine it still ran fine with the old settings. I would be checking for leaks, trying clamping it up a bit more. I encountered this after the first test drive with the new FMIC.
Checked all my piping connections all were nice and tight with no leaks. Called the guys form Ice performance they think that its probably overfueling again now that the engine is getting cooler denser air so im going to get it retuned Wednesday. I will let you all know how it goes.
Just suggesting something that you should check. I know it doesnt make sense, even in my case, but that's what the solution for mine anyway. I've had my dying pump almost a year before it was detected. On dyno the car made good A/F ratio of around 11.5:1 but tweaking the SAFC just doesn't want to change this. Very weird but the stock ECU seemed to compensate for the lack of fuel and fiddled with the timing. Only found out about the fuel pump when testing the fuel pressure and that's it. Got it changed over to a bosch item and the car is happy now with 12:1 A/F ratio and 192.5rwkw (before it wont go past 152rwkw in any boost level).
My guess, freer flowing FMIC means more airflow. More airflow is detected by the AFM and signalled to the ECU which is going into rich and retard (engine protection) mode sometime erroneously called "over boost" protection. You don't need extra boost to get it.
Just my guess of course, based on about 10 Skylines I have seen do exactly the same thing. :D
Thanks for all your replies Rs73 I will get my fuel pump checked out while it is there.
Sydneykid ive read some of your other posts about over boost protection and it made sense. If I understood correctly when I get my SAFC retuned it should fix the problem as they will be able to minipulate what flow the ECU thinks it is getting. Is that right?
Just my guess of course, based on about 10 Skylines I have seen do exactly the same thing. :cheers:
I get this exact symptom but ONLY when the car is cold... after almost exactly 15mins of driving it runs fine... go figure
I suppose it will get worse when my FMIC goes in... might have to get it looked at... lol *so lazy*
Before I got my SAFC mine did a similar thing to what it is doing now only not as bad. you probly need to one to funny it only does it when its cold.
Well I took my car to ice performance in melbourne yesterday. Found that I had dirty coil packs and my plugs wern't gapped to 0.8. The last time I took my car to a local macanic I had new plugs put in and I asked them to gap them a 0.8. So all this I thought they were gapped correctly when they were not. very anoyed. Anyway after the coilpacks were cleaned and sparkplugs were regapped the missfiring was gone. So they retuned the SAFC and the result was 196 Kw at the wheels on 10.5 psi of boost. very happy with that result and I recomend Ice performance to anyone.
I'm getting a front mount installed on the weekend.
Apart from full exhaust, pod (in cold air box), and electronic boost controller everything else is stock. Is there anything I should watch out for?
wil..
Regap plugs to 0.8 install the cooler and see how you go. But you may find installing a SAFC or simmilar will give you a lot better results as your ECU will probably see all the extra air flow and richen your air fuel mixtures with hurts performance big time.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
