hey,
I just had my r33 dyno, and the dyno was stop cuz it started to ping (was only running 0.6bar). So its time for FMIC.
I want to do it right the 1st time so im going to buy a intake plenum alone with the fmic.
I was looking at the Greenline website and saw
Trust GReddy Surge Tank
(Intake Parts) ¥73,631
Intake Plenum. Suitable for use with TRUST or standard fuel rail and injectors.
Trust Throttle Body Adapter
(Intake Parts) ¥7,363
Adapter to use factory throttle body with GReddy Surge Tank (Intake Plenum).
I was told i would need the throttle body adapter, is this ture?
and is this baiscly all i need apart from the ic?
thanks mike
https://www.sau.com.au/forums/topic/50917-intake-plenum-r33/
  • Replies 55
You may also want to take it to a decent dyno shop, I have trouble believing you got detonation at only 0.6 bar, thats like stock boost (pluss a tiny bit). Why even tune it for 0.6bar, I mean add a bleed valve and go for 0.9bar (and you may have problems with detonation on hot days - but not at 0.6)
Just a thought - I assume you an exhaust and air pod ????
Before you go out and buy FMIC and Plenum, (I personally think plenum is a bit overkill unless you have a rebuild engine and ready to run a giant boost/high HP application)
do you make sure that your pinging is:
- not caused by merely heatsoak from the stock intercooler?
- dirty/stuffed plugs, or plugs with the wrong heat range installed?
- bad injectors (leaning out)?
- dying fuel pump? (not supplying enough fuel - lean mixture)
- stuffed AFM?
- blocked fuel line?
- stuffed engine (do a quick compression test on all cylinders to make sure)?
at the end of the day, I'd say go get fmic is good, but intake plenum hmmm...
not always needed if u had stock turbo and running under 1 bar. u might better
save the money for something else and get the greddy plenum till later. Many ppl on the forum can easily get 250rwkw with stock plenum, just exhaust, ecu, fmic and upgraded turbo.
hey thanks for the reply,
my car is running 100%.
The car has some sort of custum turbo using the differnt front end and the stock r33 rear end, also the car has a ebc set to 0.6bar (no spiking) i have exhuast (catback), ait filer, bov and r34 gt-t cooler upgrade.
But yeah the place i took the car too is very good place (not a backyard job) was done a ShootOut Mode Dynodansice (whoever u spell it) V4.
Dude - your car is not running 100% fine if it is pinging.
And also - just because your AFR graph goes up and down like that doesn't neccessarily mean you are pinging.
Pinging is an un-controlled explosion - a physical sound - not measured on a Dyno Graph -
You car might be pinging tho - we cant tell from here.
A front facing plenum won't fix pinging. Get your car tuned properly. Get a FMIC with a kit that redirects the air to your std plenum.
Put more fuel in
Get a bigger fuel pump
Retard your timing
There are lots of reasons that your AFR line is going like that
Cheers,
B-Man; the person who did the dyno run isnt a no-body and know his shit. He told me get fmic. i want to get a plenum for the simple fact that if i do change my turbo there is no point me doing the ic piping 2times if i go from stock to aftermarket plenum.
Also my car is tune fine, the dyno dude said if i got a safc II, it would be pointless he wont change my air, fuel ratio cuz they are fine not too rich and not lean. my timing is stock
Man I got 180rwKW out of a standard intercooler, and only had trouble with pinging on hot days when driving it too hard for too long (heat soak), and the boost was set to 13psi, so your figures are way off the mark if you cant tune it without pinging. My guess is that there is another problem with your car.
Im not sure whats wrong with the car, it drivers very nice, (and when i run 0.6bar and push it to limiter in 1/2/3rd gear i have no pinging problems) but on the dyno it started to ping at around 5500rpm in 4th gear :confused:
my ic might possible be ****ed its a r34 gtt cooler which is bigger than the 33 cooler so i through it would cooler better.
My 1st run i made 189rwhp (on stock boost 0.4bar) my 2nd run on stock boost also went down to 184rwhp (because of heat i was told)
The car was just done for a power-run not a tune
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
