Hybrid FMIC installed Where to connect bleed valve?
What am I missing here? When you flash high beams, the factory dash globe lights up. When you set high beams on, the factory dash globe lights up. For the Haltech dash, all we are doing is picking up the factory dash globe lighting circuit, the same way it was done for the blinkers etc. When I wired up my dash it was all the same process for each dash light. I don't understand why this is becoming so complicated? -
Jump on youtube, search for bump steer gauge and enjoy the show. -
I for one would love to see this. Save the HICAS locker and subframe inserts, I haven't done anything to the rear suspension. Factory camber adjustment is dialed all the way out though.
By BourneToLive · Posted
Wow. I appreciate the thorough explanation of the diagram. I saw that same one when I was trying to figure it out on my own. Given all that information, how should I go about it? I was thinking about just grounding the other wire to the chassis to close the circuit.
