I installed a Hybrid Front Mount intercooler and had to remove a piece of the factory intercooler plumbing where the hose from my bleed valve was connected.
where can I plumb this line into now? as the new hybrid kit has no where to plumb it to i have heard you can connect it to the carbon cannister line does this work?
Are you talking about the Blow off valve?  Your Bleed valve should be located between the actuator and the turbo........not on your intercooler plumbing
yes i know but on a r33 there is a t piece which goes to the intercooler piping as well as actuator and the turbo. does anyone know where i can plumb the bleed valve?
hey i have installed this kit on my skyline and i went to autobarn and got a screw in brass fitting. once you screw it in it has the nipple on it like the factory piping to put the pipe onto.
see images
also see my gallery for install pics.
yeah i bought the fitting for $4 or so, drilled a hole a little smaller than i needed then got the right size tap and tapped the hole then screwed in the fiting with a little plumbers tape. it works a treat and has done for almost 10 months now.
i have played a little also and found that a restrictor in this pipe as in the factory one shown makes the power seem to come on better when used with a manual boost controller as before it would spike and cause the ignition timing to retard.
just an idea, seemed to work on my car anyway?
Ive just tee'd mine into the fuel pressure reg line for the moment, its what it says to do in the Trust VSPL intercooler kit instructions.
Anyone who has bought an AVCR will have a spare metal nipple which is perfect to screw into the intercooler piping after you drill a hole in it.
Has thread and is the perfect size for it.
I plann on doing this the next time i take the cooler piping off, as i want the shortest hose possible from the piping to boost controller
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
