  • Replies 59
yeah i guess it'll do for now...
yesterday I was driving to Glenny and along Springvale Rd just on the intersection with Burwood Hwy next to the Fridge (liqor outlet) is this HUUUUUUUUUUUUGE carpark and a hotel/pub as well. it'd be awesome to use as a meet spot.
I'm member number 006... just like 007 but I came first.
hi everyone!
i had a good time and i finally managed to get some faces to aliases/avatars... kinda strange actually! It was really cool to see so many nice 'lines around!
Keep up the good work!
oh and here are some shots that me and my bro took!
- he's not a member :D
photo 1: HERE
photo 2: HERE
photo 3: HERE
Kor
thats the burvale hotel.
used often, but very much east, too far for west members.
The Whitehorse is far more central in general terms
what that nong said... the whitehorse is perfect.
plus i bet they dont have 13 snhitz at the burvale!
(altho if they have coopers on tap i may consider swaying my vote :D)
lovin the Camaraderie, dont even have my car but SOOOO cant wait to come stuff around with all you guys and girls. btw im a boy and i like to cook :D (this is in no way a volunteer to cook :D)
cant wait early october!!!!
WE HAVE AN OFFICIAL SAU CHEF!!!
good work...
ok ash ur relieved of ur duties :D
Hey guys - fantastic turnout. Really good to see that so many people are supporting the club. A lot of stuff has gone on to get this organised and I can tell you that we really appreciate the response.
The club will only grow from here but it's strength and enjoyment will be more dependent on its members than those of us on the committee. And for me the most pleasing aspect of yesterdays club launch was the social interation between you guys. It was really good to see and it's something those of us on the committee hope to promote as a big part of this club.
Also good to see many guys interested in the CAMS side of things. If anyone wants anything further answered feel free to contact me.
Cheers guys.
:D
Good work Vic.
A great turnout with great people. Ash, good work with the snags mate. I don't care how they looked, it's whats on the inside which matters :D
008??? Does that mean I'm one better than 007 or am I just gonna be lucky??
See you all at MAS!!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
