Hello all.
I am expecting my 97 Stagea RS4 by the end of next week. I think I'll have the only one in Tassie but I could be wrong. I am having trouble finding a bolt in intercooler kit. Does anyone have any ideas? Do aftermarket R33 GTS-T Intercoolers fit?
Also if I buy a boost controller to up boost (I'm thinking Turbosmart E-Boost) will I need to get it re-tuned?
Oh and will an Apexi RSM be able to get rid of the 180kmh limit?
Any help would be awesome. I'm keen to find out heaps about these cars.
Thanks guys and girls.
https://www.sau.com.au/forums/topic/50959-nissan-stagea-intercooler/
From what I can tell (I'm looking into this as well), the R33 GTS-t kits *should* be the same. Mind you, I've been looking at kits that bring the pipes back to the factory location so you can use the factory pipes from where they enter the engine bay.
There may be a difference in the kits that has the return pipe coming back into the engine bay under the battery/fuse box and then over the motor etc... As the Stagea's have the battery in the engine bay and the R33's don't, there's may be problems when cutting the hole for the return pipe...
J
Hi Iburkey22, am doing as J said, bringing the pipes back in the original location. The intercooler I am using flows top to bottom, not end to end like the usual Skyline intercoolers. So the intercooler inlet and outlet are both on the same side. It used to be in the front of our R32 GTST, and the pipes line up perfectly. It also looks like the bottom brackets will line up in the Stagea. The top brackets are completely different, but for the R32 GTST I fabricated my own anyway, so I will just make some more to fit the Stagea.
Consequently I am probably not a good example for you. I will post up some picures anyway when I do it, it's a few weeks away though. :D
what are the specs of your intercooler?
It's nothing special, it was an unused spare for a Production race car (a Toy... Toyo..... Toyot...... I can't seem to get it out). They had a "homologated" spec for racing, flows a bit better than the normal Supra one, but it really cools well. I have tried it up to 225 rwkw and it has a couple of PSI resistance, but I have plenty of PSI to spare, so it doesn't worry me. Best of all it's just sitting in the rack doing nothing, with all the pipework ready to go. Should only take a couple of hours to fit.
If it doesn't come up to scratch, I have an standard R32 GTR intercooler I can use, but I don't have any pipework, silicone hose or clamps for it. I used them all on the R32 GTST. Plus I would only get carried away and make up a set of pipes with 120 degree bend at the throttle body. Then I would need to change the BOV and all the little pipes and fittings. It's a 2 day job to get it right, when all the time I should be working on race cars, not tow cars.
Speaking of which, gotta go :cheers:
so do the supra ones have the inlet and outlet on the same side?
or am i interpreting what u said wrongly?
Yep, that's why I originally used it on the R32, it was easy, quick and cheap (as in free) and the pipework only took me an hour or so to fabricate. :D
would this mean less cutting out to fit the pipework into a stagea?
On the R32 GTST, I designed the alloy pipework so that it fitted straight up to the standard steel pipework, starting from where the standard intercooler was removed. If you look at it from the engine bay it is impossible to tell that an aftermarket intercooler was fitted. No "cutting" was required, so I can't see any reason why there would need to be any on the Stagea. There is heaps more room in there. But I won't know for sure until I remove the Stagea bumper bar and get into fitting it.
Hope that helps :D
Mad Wagon. I noticed in the pics you had an RSM on your dash.
I want one of these to get rid of the speed cut in my car. I just wanna wind her out on a desolate road near my house one time to see how fast she'll go. Plus I'll know how fast when my normal speedo goes off the clock. Do these work O.K.?
Thanks for your help so far. I'm very grateful. I think I'll go with the HKS kit I'll let you know how I get on.
Prepare to be bombarded with questions cobber.
Where did you buy it? How much? Who fitted it? Is it any good? What did you do with regard to the Battery? Relocate it to the boot or buy a smaller one?
I'm finally getting somewhere with this whole intercooler thing. It's great. Now I just need my friggin car. Ernest told me they would put it on a truck tomorrow but when I rang today he said they'd stuffed some paperwork up and I'd have to wait longer. I'M SICK TO DEATH OF WAITING!!! GRRRRR!!!
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
