undo'ing one of the links will take the sway bar out of the equation as it effectively means its just hanging off one side and not under any tension
i have the same problem as you, caused from the same thing (gutter), and unfortunately i know what the problem is.... bent chassis rail :D
anyone know how much it would cost to get it straightened out if i remove all the necessary parts for a panel beater to get to the rail ?! sorry bit off topic..
I'm not sure if this is the same sort of problem, but mine was weird
but when I had the std suspension taken out of my 32 GTST it was leaning to the right. put new shocks and springs in, made the height adjustment and it still didn't help
In the end the guy had to have a custom bracket made up to bring the right side up to the height as the left
mark
i might have to see the guys down at fulcrum ( spelling?). when installing the top arms what would cause one of the bolt holes to be out of alignment? when i put the stock items back in after the adjustable ones died, i put the bolt through the one at the back then tried to put the bolt through the one at the front and it was out by about 5mm. anyone?
  • 4 weeks later...
ok i know its been awhile but i have been busy. went down to fulcrum this morning and they didn't even pickup on the height difference. and here is the specs sheet they gave me.
There are whole pile of little issues that I can see, not one big one. I have read back through this thread and I can't see the rear height measurements. I know the front is 380/350 (L/R) but what is the rear?
With that information, I will write up what I suggest you do and what settings you need.:)
quick check , have you got the 'a' s on the front upper arms on the outside of the car, the arms only go in one way. Also they have to be torqued up when the car is at normal road height, possibly they may not have tightened one of them properly.
Also is there any packing behind the plates that the top arms mount too - on the body, maybe someone has tried to adjust the camber that way.
Stephen
no.. i completly took off the adjustable arms and then fitted standard items and there was nothing there.. when the left side went in it didn't line up with the outside bolt, i had to twist the arm to get it to line up.. and yes the arms have the a to the outside of the car
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
