I just got my car tuned around 3 days ago then 2 days I tried the car and push it till 7k rpm. Suddenly out of nowhere the engine oil light flash when I rev hard till 6.9k on 3rd gear which happens occasionally.
Any idea what happen to the car?
it's a r34 gtt with full exhaust, fmic, panel filter, avcr and power fc (tuned at 1 bar)
Cheerz
Erik
https://www.sau.com.au/forums/topic/50996-problem-about-engine-oil-light/
Guest RedLineGTR
when you do take it back to the tuner make sure you also tell them with what conditions this was happening such as really cold weather etc, most tuners leave abit of leway when tuning so these things dont happen, just try and make sure you dont spend more money on getting something done that should of been done while in the first tune. My 2 cents. Rob
PS. Also a good idea would be to see if anyone will lend you thier hand controller for like a week after the car has been tuned up again, for you too see the details of the power fc to make sure you know 100% that the car is right.
Paul : I checked my oil level, it's just normal or quite high. I made a mistake it was my engine light, any idea what happened to my car paul?
R34GTT : Yeah I checked it when it flashed, it read 35 (max)
Rob : I'll take it back I guess this friday for a check , I'm pretty much not happy with it. btw I got hand controller
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
