Suspected Problem : Faulty Coil Pack ? ? ?
At hi revs usually 5500+ start to get back fireing and lack of performance.
Pulled all 6 coil packs out, inspected them all, put them back in, whilst doin that pulled all 6 sleevs out and inspected them at the same time, proceeded to put them all back in, took for a drive, problem fixed... temporally. Been driving since then and stated to happen again. Can anyone suggest anyways to test individual coil packs anyways besides pulling out one by one and swapping over wit a new one... anyways with a multi meter?
All replies & help would be appreciated.. hate to see my car being sick all the time ;)
  • 5 weeks later...
All replies & help would be appreciated.. hate to see my car being sick all the time  :P
There are a few threads on faulty coil packs in this forum where people have used electrical tape to seal up micro cracks in them. These cracks were the issue... as far as testing them goes, i have no idea but a search should yeild more.
Are you running standard boost? I had the same problem with mine and thought it was coil packs. It was actually the spark plugs, got them replaced and regapped to 0.7.
When i turned the boost up got a similar problem but that was due to running to rich and too much timing. Hope this helps.
Steve
I've read through a lot of coil pack problem threads and i have a question - i am experiencing popping up at high revs on 1 bar boost, it was fine but it started happening all of a sudden. It happens over 5500 rpm, under load - the popping happens a couple of times per second. My mate had the same problem and took it somewhere and they replaced all his coil packs. What i was wondering is to identify the problem coil packs - is it safe to unplug one, take the car for a run and see if the popping stops? That way i could see which coil pack(s) are to blame?
Just a thought.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
