  • Replies 148
Posted Images
Go the Splitfire coils worked a treat on my car and only costed me $600 for the coils and fixed all of my problems!....tryed the tape and recoating the original ones and only worked for a little while.....araldite goes soft over 60 degreese and loses its shape and it gets dam hot near the coils!.....Splitfire all the way! car is so much stronger now!
Well I've done some limited stuffing around but couldn't be botehred with what seems like a temporary solution which is why I'm gonna pick up some SplitFires.
There's a group by in my sig, $640 which might not be as cheap as Nengun (only if you manage to dodge GST and customs), but that's a guaranteed price to my door. I don't mind paying $40 for the piece of mind.
Forums are great!!!
I've been stressing about this problem I have where at 5kRPM, I lose power and get backfires.
I think my problem is coils!!
I though it might have been fuel pump or fuel blockage. (i realise it could still be this)
What I want to know is does this cause any problems to your engine - like leaning out fuel would? Asumming that coils are the problem..
Forums are great!!!
no, the only problem you may find is that your spark plugs are fouled due to the bad misfiring, although i drove around with the misfiring for maybe 200kms (reasonably softly most of the time) and the plugs were still ok afterwards.
so check plugs when u change the coils, other than that nothing really bad to worry about it wont blow up :P
so check plugs when u change the coils, other than that nothing really bad to worry about it wont blow up :cheers:
RAD!!! Will check those sparkys...
Have recently taken the electric tape approach
Has had a huge improvement on the power in my car
no popping and missfiring at 4500rpm
is still however lacking power around 6000rpm, but it doesnt missfire, just lacks power
I did however find a neat way to fix the carbon rod which comes out the end of the coil pack
One of mine had totally fried out, along with heaps of corrosion on the spring
I had an old distributor cap off a Gemini lying around and sure enough the carbon rod was the same size
Bonza, old crappy coil turned brand new
saved me $80
Just recently Ive been experiencing some real bad missing on cold idle, also under load at low revs when cold, basically the more throttle the worse the miss and the less power it makes, it occasionally pops when I rev it out as well.
Now I just spent an hour or so pulling out my coil packs and taping the entire sides and stem up with electrical tape, most of them had scald marks and a few had hairline cracks so I put some araldite on those as well. Anyway started the car up and its exactly the same, no improvement at all :)
Im quite annoyed, I also replaced my O2 sensor due to average fuel economy with an EL one, hopefully that will at least improve (15-16/100km)
this is all in an eccs redtop r31
Hey Zahos,
In regards to regapping the plugs,
Did you regap them to .8mm?
Chriso
Just thought I would update this thread with some more info....
Although my coils were covered in araldyte, they started playing up again on the weekend, so I pulled them out including spark plugs to see what was going on....
Well first of all, my tuner gapped my spark plugs like so:
1:0.6mm, 2:0.7mm, 3:0.7mm 4:0.75mm, 5:0.6mm, 6:0.6mm
not to mention a whole bunch of bolts missing all over the place, but anyhow, once they were re-gapped I turned to the coils.
Upon inspection the araldyte looked fine. No cracks, no chips.
So I took the rubber boots off, and the little springs inside the shaft and notice the shafts were a little corroded (that blue/green crap you get on your battery terminals). So I sprayed the shafts with WD40, and cleaned them out with steel wool. The car runs better than it ever has now, and is very smooth.
So also take this into consideration when looking at your coils.
Z
Yep replaced my sparkplugs and gapped them to around .8 my method of gapping probably wasn't the best however. I also sanded the end of the carbon rod which was fouled and burnt looking on all the coil packs.
I'm no expert, but it doesn't sound like a good sign (I could be wrong)
I spent ages cleaning them with steel wool and it made little difference.
Took me 30 seconds to clean with WD40 and worked a treat!
I cant be sure that yours are facing the same issues without looking at them though.
Ive bought a 2nd hand set of coils for $150 in better nick then mine, so when they arrive Ill pull out my old ones and properly covery them in several layers of araldite as I didn't cover all the scald marks in tape, and Ill try out the 2nd hand ones.
Hey great post, I have learned a lot. :uh-huh:
I have an R33 GTS-T Series 2 and from your posts noted the coils are different from series 1 to 2. Would anyone have the Spitfire part number to suit.
I’m yet to pull the coil packs out but I have been experiencing misfires at 4.5k RPM and above. Last night in Canberra it was 0 deg and the misfires were occurring from 4k up to redline. I have noted during the 30 deg days I get 1 only misfire at about 4.7k. Still sounds like the coil packs? Hmm.. will be sure to check the plugs and leads to. I figure if the silicone / glue fixes the problem I'll get new coils.
M@
ok just ran some injector cleaner through my car, only used 1/4 the tank so far and it got rid of 90% of my popping, must have been some bad fuel.
Anyway it still pops up high revs and loses power/hesitation so Im gonna replace the coils anyway
Just to follow up my progress:
Removed the plugs today and cleaned them with some WD-40. Also cleaned the spring contacts (from coil packs to spark plugs). This solved 100% of my misfires. :)
Just purchased a gaping tool and ready to gap em to 0.8mm.
Quick question: The performance shop recommends replacement plugs with 11mm gap standard. GSK Platinum stock code ....-11.
Once I replace the plugs should I re-gap the newies to 0.8mm? If so why (performance reasons maybe)?
Thanks
M@
Hey Matt,
Good to hear your problem has cleared up...
In re to spark plugs, don't waste your money on platinums...
If you dont mind changing them every 1 - 2 years then get a set of coppers as copper is a much better conductor. and at $3 - $4 each, better value.
Get some NGK BKR6E which are gapped at 0.8 already. Best to check them still though...
If you cant find any, BKR6E-11 gapped down to 0.8 are fine too....
If you cant find those, then BCPR6E and BCPR6E-11 will be fine also.
Gapping to 0.8 will ensure a more reliable spark.
So is anyone taking notice of the Qld maintenance day thread on installing Buick coil packs that won't be as heat affected and way cheaper? I've been thinking of that for a while but they are on to it already.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
