  • Replies 148
Posted Images
Listen to what Rolls has to say
I jsut put some octane boost/fuel system cleaner through my car and my car revs straight out now, no stopping, popping, nothing
is the only thing that has changed since i taped up my coils.
taping fixed it for a week but then it went back to normal
i think i may definately have to get my computer reprogrammed to run on 98 octane fuel as i cant afford to be buying octane boost ever tank of fuel
Yeah my popping was due to an injector problem. I ended up getting coils that definately worked and I still get the popping.
Using your standard electrical tape is not a permanent fix b/c the tape shrinks with heat.
It must have been a fluke with the octane booster b/c the difference that stuff makes is negligable in my experience.
So how are the coil packs hanging out guys ?????? An update as to whether the araldite works would be nice.
Hey rickhead,
I've been using it for 10-11? months now... still runs PERFECTLY.
If you do it though, make sure you do it right and spend the time to put plenty on in the right spots...
Howdy 'yall.
Just thought I'd mention that I had the problem, checked my colis and found 4 out of 6 coils had cracks. I areldited them up and the misfire has gone.
It's been 2 weeks now.
Thanks to all who contributed.
Chris
Guys,
I went against the trend here and used Roof/Tile/Gutter silicon. Its rated to 150 degrees C and I covered the entire pack in a thick coat leaving ony the plug clear.
I also gapped my plugs to 0.8mm since they were at 1.1mm. Seems fine so far but early days yet.... Update in a few weeks.
PS: Be careful when you put the coil pack bracket back in (the metal strip that hold 3 packs) it goes in a certain way. It even says UP and Front or rear on it. I missed it and almost cracked my coil packs :) whoops..... just a heads up!
I had a look under my bonnet when the car was warm and in the very dark I can see arcing on I think all of them!! They are not meant to do this I think. I might be better going for splitfires then. I have a used car warranty so I may be able to get them under warranty...we'll see.
They appear to be about 570 for the set - not too bad!
I can't believe the car is running well untill you get to 7psi or so. Looking forward to smooth running at 9 or 10psi :)
You have to look very hard for the arcing. I'm just running it woithout the spark plug cover and because its series one I have just cable tied the module to the brake lines...
I have pics but have been unable to post them but i got rid of the Standard Coils and have replaced them with Bosch 716 MEC coils $250.00 for the coils and $50.00 for leads works with the standard series 1 ignitor if i can post the pics to someone to upload them PM with your email address and i will send them
they are quite big though as the camera is 6 meg
Rob
On the same subject has anyone seen or used the AEM setup advertised in HPI occasionly? It has a plug for the ignitor to connect to and then it used leads like an ordinary setup. It claims superior performance to OEM coilpacks.
Anyone know the cost or had any experience with it? I imagine from the sounds of it the Bosch is a similar setup?
If you can see any light around the coils they are leaking right? I can only see it when it is very dark and it is only quite faint. But it is definately lighting up on 3or 4 coil packs.
The mechanic couldnt find it today. Maybe it wasn't dark enough..
is it possible to post this article regarding the ARM setup. Seems interesting.
my car has not missed a beat since fitting the Bosch coils and the bonus is now changing plugs takes next to no time I do not even have to remove the crossover pipe.
the good thing about the bosch is i can at a later date fit a CDI to the coils
I only have faint light from the coils at idle. Can only be seen when very dark. Is this what is causing a misfire do you think? The mechanic reckons it could be CAS or module. He thinks you would see more arcing if it were a problem. He ran it on he dyno and could not see any big arcs. although the car was not that warm I don't think
Does it have to be a big arc to cause a misfire??
Im pretty sure any arc at all will be taking current away from the spark which will at least weaken the spark, possibly causing a misfire.
If you can see where the spark is coming from, cover that area in glue/tape etc until it stops arcing and see if this fixes it.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
    • Would be interesting what the price would be without the barracuda wheels. Looks like he dropped it down to 40k. Maybe his mate wasn't correct about the 50k evaluation. Has always been a dream of mine to own an auto 33. Looks like I'll have to keep saving my pocket money or ask mum for more pocket money.
    • Thinking about importing a stagea as a family car since i’m getting married this year, thoughts? Me and my fiance both like stageas, but don’t have any experience with them
