benl1981 Posted July 1, 2005 Share Posted July 1, 2005 Its coming from the side of the coil. Does this mean there is a small crack on the side? You can see burn marks on the side from where it is getting warm from the little leak.. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1441095 Share on other sites More sharing options...
spx25t Posted July 1, 2005 Share Posted July 1, 2005 Are the bosch ones like the Nissan/Splitfire ones or like a lead/distributor sorta setup? UMMM yeah I dont know the way it is set up is that the coils are mounted on the rear firewall and the ignitor has been move to sit underneath the Coils and then just run 6 leads to the spark plugs directly from the coils Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1441171 Share on other sites More sharing options...
Rolls Posted July 1, 2005 Share Posted July 1, 2005 Its coming from the side of the coil. Does this mean there is a small crack on the side? You can see burn marks on the side from where it is getting warm from the little leak.. yep means theres a crack, tape/glue it up and see if it improves Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1441185 Share on other sites More sharing options...
neo32 Posted July 1, 2005 Share Posted July 1, 2005 where u tape coils like attthe bottom part underneath any help please Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1441972 Share on other sites More sharing options...
noise Posted July 1, 2005 Share Posted July 1, 2005 I will be having a look at my coil packs this weekend, as I currently have 4k-5k+ rev problems. I think I will clean them first and have a good look, and glue them if cracks are obvious. I think replacing them will be the best option in the longrun. Will let you guys know how I go. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1442040 Share on other sites More sharing options...
noise Posted July 3, 2005 Share Posted July 3, 2005 OK so my mate helps me take out the coils on my GTT. We look at all of them and can not find a single crack or blemish, they all look new. We tape them up anyway and go for a drive, problem is still there. So we decide to gap the plugs at .8, SO FAR THE PROBLEM IS FIXED!!! He reckons it will be fine from now on, I hope he is right. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1444307 Share on other sites More sharing options...
Bazelinez Posted July 3, 2005 Share Posted July 3, 2005 Yeah when my plugs were new they were fine at 1.1mm but as they get older and blacker they need to be set at the proper 0.8mm.... Its worth the time to do it. I'll try and remember next time Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1444623 Share on other sites More sharing options...
SECURITY Posted July 3, 2005 Share Posted July 3, 2005 hey guys.. just wondering if urethane would be better than the araldite glue.. does anyone know? Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1444926 Share on other sites More sharing options...
chrissso Posted July 4, 2005 Share Posted July 4, 2005 hey guys.. just wondering if urethane would be better than the araldite glue..does anyone know? Hey, It all depends on whether urethane is heat proof and has good electrical insualtive qualities. Basically you need to insulate the coil packs from arcing if there is a crack in them. Use whatever, as long as its heatproof to about 130 deg c and is an electrical insulator. Chris Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1445597 Share on other sites More sharing options...
SECURITY Posted July 4, 2005 Share Posted July 4, 2005 urethane is pretty strong.. they use it in waterproofing bathrooms etc.. ill give it a go and let you know how it goes Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1445641 Share on other sites More sharing options...
SECURITY Posted July 4, 2005 Share Posted July 4, 2005 well i did it, i just used a razor to apply a liberal coat onto the front of it where i saw the crack (only 2 had cracks, and 1 had a burn mark) .. im going to leave it for a while to dry.. heres how they look now.. ill post results later. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1445802 Share on other sites More sharing options...
Bazelinez Posted July 4, 2005 Share Posted July 4, 2005 I coated the entire pack up to the socket when I did mine, probably over kill but its been 3 weeks now and its still fine. I used roof and gutter silicone, good up to 150 degrees. Only cost 6 bucks for the tube. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1446316 Share on other sites More sharing options...
SECURITY Posted July 4, 2005 Share Posted July 4, 2005 i just stuck them in and now its running alot better.. its still early to tell if the urethane is reliable or not but so far its looking the goods.. it costs around $18 a tube for the urethane.. im just not sure what the heat resistance is. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1446340 Share on other sites More sharing options...
race_snooze Posted July 4, 2005 Share Posted July 4, 2005 tried this with alrodite (how ever you spell it) still got 5k missing problem, have to bite the bullet and get some spitfires i think. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1446700 Share on other sites More sharing options...
WLD747 Posted July 4, 2005 Share Posted July 4, 2005 ive had the same problems, but in the end im purchasing new coils, they are not spitfire ones. This guy in NZ is selling them cheap and provides a good spark. http://gdz1la.kol.co.nz/ i have purchased it and yet to put it in, but the feedback from customers is great. No more missing at idle or revs. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1447215 Share on other sites More sharing options...
chrissso Posted July 4, 2005 Share Posted July 4, 2005 tried this with alrodite (how ever you spell it) still got 5k missing problem, have to bite the bullet and get some spitfires i think. Hey, Have you checked your spark plug gap? What boost and mods U running? Just curious... Haing a look back in the thread, it seems that most problems are either cracked coils or bad spark plug gap. If it wasn't this then it was fuel problems.... like fuel cut or blocked injectors... Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1447220 Share on other sites More sharing options...
SATO GTS Posted July 6, 2005 Share Posted July 6, 2005 what series of coil pack are we talking about?? series 1 coils are different to series 2 coils. i have series 2 coils and never had a problem with any break downs or missfires what so ever. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1450560 Share on other sites More sharing options...
MFX Posted July 13, 2005 Share Posted July 13, 2005 You guy's are Legends!!!!! My RB25 180sx has been missing from about 4 grand fro ages now. It has been driving me nuts. I pulled out the coli packs and there didn't seem to be any cracks, so i just taped them up to be sure. That didn't work. So I followed the advice to pull out and gap all the plugs and also sprayed the small coils under the rubber boot with WD40. Now the thing is running beautifully again Thanks again! Top thread! Jeff. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1461432 Share on other sites More sharing options...
riceline Posted July 14, 2005 Share Posted July 14, 2005 I have done this as well.. Yet to put them into the car. One other thing I did was get some VHT Engine Block paint (400+ Degs). Taped up the electrical contacts and the very stem of the coil. Then gave them about 5 complete coats each. Now I know that every possible section of the pack is coated one way or the other. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1463311 Share on other sites More sharing options...
WLD747 Posted July 14, 2005 Share Posted July 14, 2005 did the vht engine block paint on my coils (fire red). Seems to keep em cooler and works great. The only problem is they take a long time to dry. I have done this as well.. Yet to put them into the car.One other thing I did was get some VHT Engine Block paint (400+ Degs). Taped up the electrical contacts and the very stem of the coil. Then gave them about 5 complete coats each. Now I know that every possible section of the pack is coated one way or the other. Link to comment https://www.sau.com.au/forums/topic/51046-faulty-coils-misfire-at-high-rpm-read-this/page/6/#findComment-1463323 Share on other sites More sharing options...
