I need help!! I hope somebody here can shed some light into my problem
I had a little mishap awhile back and had to replace my exhaust cam with HKS 256 with 8.8mm lift as well as my CAS and timing belt, About the same time my bosch 910 was installed in the car.
This was done by a mechanic that didnt seem to have great knowledge on import cars
It ran ok for awhile but the idle started to get rougher and rougher
it stalls sometimes at the lights and if I free rev it, it would stall
Now the car cant even idle, if I let go the throttle it would just stall :D
sometimes when Im driving and I let go of the throttle, the engine would start struggling (can hear popping in the exhaust) But it seems ok at higher revs or when the car is allready rolling but there is shit all power
Cold starts are horrible have to pump some gas and the engine takes awhile to start (can hear this strange clicking noise as well)
I know the car is for some reason running REALLY rich... the wall behind my car is black from all the crap that comes out of the exhaust, and 40L of fuel only gives me 200km
I've checked the engine for airleaks but there seems to be none. I've tried grounding the fuel pump, replaced the coils, the TPS and AFM seems ok because Im still getting correct readings from the SAFC. Yesterday I tried plugging a wolf3D I just bought and the car wont even start. Oh if it means anything, unplugging the O2 sensor didnt seem to do anything
My local mechanic seems to think there's something wrong with the timing, something about the CAS sending the wrong info to the ECU. because something wrong with how the cam was mechanically installed, been meaning to take it to an import workshop but thought I would get some opinions
Is this just because standard ECU cant take 256 ex cam? or is the CAS screwed? or maybe the cam wasnt installed correctly? Maybe a problem with fuel system?
so any ideas?
my mods are:
Trust MX cat-back
SS highflow cat
RSR front pipe with stock dump pipe
Apexi filter
TRUST V-SPL intercooler kit
SAFC-II
Greddy Profec B EBC
HKS 256 exhaust cam with cam gears
Bosch 910 external pump mounted inline without surge tank
malapassi FPR
Wolf3D on the side waiting for me to fix this problem
sounds like it could be timing... similar thing happened to my car after i got the timing belt done... car was running really rich and would pop all the time... at traffic lights it would stall... my mechanic just plugged in some sort on analsys computer (into the plug under the fuse box) into my stock ecu and found the timing was out. changed the timing and the idle a tiny bit and the car is better then ever :D
mods: fujitsubo cat back
safc II
avcr
fmic
Hey Evil did your problem occur right after you got your timing belt changed or did it slowly get worse and worse?
it was as soon as i left my mechanic... i noticed the car had gotten louder and stalled at the lights... i went straight back and thought that the idle needed to be adjusted, had that done and left... it was a really rainy day so i did not drive on boost on the way home. the next day was nice and dry, i gave it some some and the car ran like a dog... got the timing adjusted, back on the dyno for an safc retune and the car has run great ever since... idle was set to 740rpm and my RSM shows that it only ever goes + or - 10rpm! car is smooth on idle and it sounds quiet again... :thumbsup:
Did you have the SAFC II retuned after you intalled the cams? Im guessing that you should get someone to look at your timing and air fuel ratios.
Yea I did have the SAFCII retuned and the car was running fine with 273rwHp for awhile but this problem started to show up and gradually got worse
Its not a spark jumping sound you can hear is it?Maybe have a crack in a coil.....could also explain exhaust popping...or is more of a mechanical noise?
I allready replaced my coils and it didnt change anything
The sound is only when Im starting the engine
it cranks over and then theres this mechanical click and the engine doesnt start
My local mechanic says the sound means the timing isnt right
Hey Evil turns out my problem was the same as yours, sort of...
my bloody mechanic didnt tighten the CAS bolts and it was bouncing around as the cam was rotating
tightened it and set to 30Deg and all is well
thanks for the help people
  • 3 weeks later...
GAGH! just when I thought everything was well
this damn problem comes back to haunt me.
My timing never seems to want to stick to 15deg
After a week of setting the base timing, the car starts to idle badly once again
when measured with timing light its nowhere near the markers but the CAS hasnt moved an inch!
I turned the CAS all the way to one side and the markers are still lightyears away from lining up
Sounds like a stuffed CAS or am I wrong?
oh and I have a HKS cam gear, Im just wondering if my mechanic installed it correctly, is the white dot on the outer edge (in between the teeth) suppose to line up with anything?
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
