I have a Nissan Cefiro that i am thinking of selling, i Imported this car late last year and have done a few mods to it, It i a factory manual which is very rare in cefiros. I know what my car is worth so im not going to take some stupid offers.
Info:
RB20DET
5spd Manual
ABS
LSD
3" Mandrel from turbo with screamer
7" Supercat Cannon
Lowered Espelir Springs and Struts
Pineapples
Auto Meter Boost gauge
Auto Meter Air/Fuel Ratio
Auto Meter Shift Light
Aftermarket Leather Steering wheel
Aftermarket Gear knob
Turbosmart Type II BOV
Greddy/Trust Air filter
Blitz Turbo timer
Fire Extinguisher
Pioneer CD player
Front Pioneer 6" 3Way
Rear Pioneer 6" 2Way
Complied with 6 months QLD Rego
Pics for this car can be viewed at my website, i live on the sunshine coast. If you wish to contact me you can email me at [email protected]. the pics on the net were taken before it had most of these mods. I will get some more recent pics up soon but you can get the idea of what it looks like.
Lost licence again, needs to go
$12000
Thankyou for looking
Brad
https://www.sau.com.au/forums/topic/51088-nissan-a31-cefiro-rb20det-5spd-mods/
  • 3 weeks later...
  • 1 month later...
hey r u interested in swapping for my 1992 r32? if u are, have a look at my post in cars for sale.
if u are keen u can of course take off parts from ur ceffy to make the deal more worth your while as ur ceffy has a shitload of bolt on bits, cheers
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
