hello.
i would like to know if it would be ok to put an sr20det into the r32 instead of having the rb20.
what would i have to do? how much would it cost to get a good sr20det engine?( low k´s god conditions ets..)
were should i go to get the engine? how long will it take?
would insurance say anything?
plzzz help i will be gating a car soon so i wanna know if i should get the r32 to do this on it if its possible( i got big plans 4it just need da car n den da money.
thanks 4d tym n sory 4 da long post n the trouble....
thnkz :)
https://www.sau.com.au/forums/topic/51122-r32gts-wif-sr20det/
hello.
mate, I reckon it would make a sweet conversion. Like Toshi said, Meggala has done this alread (and SR20 into cefiro too) so he could give you some advice. I reckon if you're not doing much yourself and want to add some goodies whilst you're at it, then you should try and have around $10K for the conversion. It will be sweet though, and different.
Best of luck to you.
Richard
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
