Random pull overs.. when were you last pulled over?
I was wondering how often W.A skyline drivers are getting pulled over these days whilst driving along minding their own business... are the cops still going nuts with yellow stickers or have they toned down a bit? What areas do you think are police hot spots?
  • Replies 71
It seems most the pullovers are late at night. What sort of areas were you guys in when pulled over? Has anyone been pulled over during peak hour before?
First time I was pulled up on west coast drive in north beach in the middle of the day.
Second time was on the Boulevard in Floreat at about 8pm
I was pulled over after picking my car up from the previous owner. I had owned the car less than 5 minutes.
In all i had 3 pullovers and checks done. All were routine license checks that ended up with my bonnet up. No yellows were issued... Also 2 were afternoon and 1 was night.
All times ive been pulled over ive deserved it ........ everytime ive never been asked to pop my bonnet.
Even had police drive my car and were rather complimentry about it after :D
0 yellows *touch wood*
hmmm reminds me - gotta work out how many points are left on my license ..... lost 4 points the other day to a police officer who was hiding in someones front yard behind their shrub in an unmarked car with a radar at 9am on a saturday morning ..... prick!
i found that when attending car cruise's you up your chances 100 fold of getting pulled over and defected. when just normal driving the police dont seam to have a problem at all as long as your not attracting attention to yourself.
If only that were true, the vast majority of time I haven't been on a cruise, and just been sitting in traffic. The cops single me out from all the rest, just cause it's an import:(
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
