  • Replies 249
should still be 10 or more.
Paul can u please send me the list of people that have made payments and how much.
Also can you try and get postage costs on those addresses i sent u and email them to me.
Paul, i sent you a PM last week, did you get it?
If this is happening soon i am still in, as i have not seen the money in my account, thus i have not bought the harness from another place.
paul whats going on man??? gotta a lot of people waiting on a response...
can u send me the list of whos paid and who hasnt?? and what they paid??
otherwise your just going to have to organise a refund... this is taking way too long
I recommend that all parties involved get their money back and we shall seek out a supplier else where. I understand that such problems can be out of everyones hands, so if everyone agrees i will request all funds deposited back into our accounts.
From here i will contact a new supplier and see what deals they can do for us.
thats what ive been trying to organise for about 2 months now but i still havent received a list as to what people have paid... its getting beyond a joke and is making ME look bad because im the front man that went to all the other ***in forums to get the numbers.
posting on behalf of Paul:
"Due to the supplier of the belts being involved in the Tsunami disaster,
with his 4yr old son being swept away while on holiday in Phuket, I am
unsure as to when/if the belts will arrive. I'm not sure when he will be
returning back to work, so at this point in time I think it best in
everyones interest to refund all deposits.
This is an unfortunate circumstance, but rather than having further delays
to the groupbuy, I think it best that everyone has there money back. I
apologise for any inconvinience, but this disaster has had wide-reaching
effects.
To get you money refunded please email me at [email protected], along
with the amount you deposited and which account you would like the refund to
go to. I will try and get everyone refunded as quickly as possible.
Regards
Paul
If everyone is still interested I am sure I can get a set of harnesses at a discounted price from another supplier (Meridian Motorsport).
Most probably they wont be the same brand or the same price (they may be cheaper or a little bit more), I have to discuss this with Meridian Motorsport. They have previously looked after us with the oil cooler kits and I am sure they will do the same for these harnesses as I have already mentioned it briefly. He will most certainly NOT take nearly as long to supply the goods.
PAUL: The Tsunami disaster was a great and sorrowful tragedy, with the unfortunate lose of innocent lives. I am sorry to hear that the suppliers son has passed away due to this event.
But to use this as the only excuse and only update, after many months of waiting, is absolutely disgraceful and appalling.
Guest
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
