  • Replies 249
Ok, good news and bad news.
The supplier has sold out of the SABELT's which they were able to do at the cheap price, they sold 50 in 2 weeks in WA alone:(
But fear not, we have been offere another belt which is even better:D There SCHROTH harness's, the Profi III-5. These have a carbon-buckle and fully sprung adjusters which make them a better belt than the SABELT one we were looking at. RRP is $599, for 10 or more we can get them for $385 which is a real deal:D
If you want to look at them go to www.schroth.com Products->Motorsport->Restraints-Profi III-5.
They are avaialable in blue, red and black, with long or short straps.
Inark, Can you email/PM those interested just to let them know. I will be going to the shop tonight to check them out, but have been promised they are a much better harness.
Cheers
Paul
can you send me the bank details paul... ive pretty much just stated.
Delivery ill be worked out depending on where ur from...
Pickup is available if in WA...
Deposit of $50 to confirm...
xfer with NAME DEP (number of belts) into the WA account
so for an example... inark DEP 3
And the remainder will be required once all 10 positions are confirmed
this is more so for the person buying them... especially being from other forums and not knowing me or anyone else... more a safety thing for them... this way they only lose $50... this is how they see it.
I thought the original $350 price for the Sabelt was including delivery...
What are the chances of them getting more Sabelt harnesses in stock?
Read the posts :P
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
