hey guys just wondering what sort of mods on the rb20 will give you around 230kw and if the injectors need to be changed then?
Personally I have never been able to get over 180 rwkw on the standard 270 cc injectors and that is with an adjustable fuel pressure regulator and a GTR fuel pump. I have 550 cc S5RX7T injectors in mine and Roy has GTR 444 cc injectors in his, if I remember rightly.
Hope that helps:cheers:
  • Replies 90
Hi Roy, Did you end up just getting another 2nd hand RB20? What kind of warranty did it come with?
That 222rwkw is a nice figure did you get ICE to tune it for you? What kind of air/fuel ratio are you running?
Any chance of posting up dyno graph?
Too many questions i know! :mad:
Yeh it was another 2nd hand engine. I did 2,500km on it with 3 sumps of oil before I got ICE to tune it. The engines normally come with 3 month warranties, but if you have modified bits (turbo, ecu etc) going on the engine they will more then likely only give you a start up warranty.
Yeh ICE tuned it. If I can find a scanner the ill post it up. Im a pretty hard man to please but I am happy with the tune. Drives really nice and from what im told is under what the turbo is capable of…LOL noone can decide if its all the engine is capable of or should we wind a bit more out of it. But the tuner has done the right thing whats the point of getting another 20-30hp if it means I need a tow home from Phillip Island:)
I don’t know what A/Fs as the graph I have only has power and boost. It doesn’t even have all the dyno settings down the bottom so doesn’t really tell you much other then at 4,000rpm it makes 84rwkws:)
Good stuff mate, when are you due over?
will have to take you for a spin in my car when you are here :mad:
Im not sure if that’s a good idea, id hate to go for a ride in your car and realise it makes the same power but with better response. For the time being im happy:)
But I have noticed that my power tapers off abruptly at just under 6,000rpm so maybe time for those cams:(
Im due over next Sunday thru to Friday 12-Nov-04
My power does a similar thing, Shauns thinking is that my dump/exhaust is a little restrictive, the dump pipe is a cast HKS item, but the front pipe upon measuring isn't a full three inches, more like 2 3/4inch pipe, so there is a little to be had there I think
apart from getting the boost controller sorted, I will leave mine as is for the summer and once the weather cools a little then might get my sapre motor's head ported and fit the GTR cams and gears :mad:
Will definatly catch up when you come over
Chris
Chris
Another night for drinks / and or meal?
Hope to catch up again Roy....i did like your car last time...plenty of go in that Trust turbo...mmmmm :aroused:
Mine'll be going 100% by then (stage 1:D), and Joel's on his run in stage....
nice mate, lots of grunt and a nice stable boost curve, it doesn't nose over too much up top
time to get my ebc working, hopefully for a similar result! ;) I will scan mine in over the weekend for a comparison
Chris
Chris
Ive never had prob with my AVCR…but I hear ppl say that AVCRs spike a lot and cant hold stable boost. :confused:
Would you believe I have my wastegate spring at 8psi and using the AVCR to dial in 12psi and 17psi. It creeps a little up top to almost 18psi but its pretty stable considering the soft wastegate spring im running…so in short, nothing wrong with AVCRs:thumbsup:
Yeh Duncan the thing starts to plateau a little at 6,000rpm, power cure doesn’t nose dive but I would have thought she would swallow a little more air up top. Looking at the result im starting to think about some 260/270 - 8.8mm lift cams again. Imagine the idle :whackit:
I have to say im pretty stoked with the results of the tune, the numbers don’t look all that flash on paper:( but on the road it feels not too bad
Was the dyno run in 4th gear? If so the graph stops at ~6,150 rpm, I hate it when they stop the graph, I like to see what happens all the way up to the rev limit. It is hard to tell where to change gear with a graph like that. Standard cams usually make max power at just over 6,000 rpm, so it looks quite normal. The reason it feels OK on the road is because it makes 5 psi at ~3,750 rpm and 10 psi at ~4,250 rpm. That's pretty good, a little bit of camshaft timing and some more lift would bring that down a few hundred RPM.
If the dyno run is in 3rd gear......well you have some work to do.
:D
*looking around for the "cold bucket of water" smiley after SK's comments* :D
As always, valuable comment. Now if only Roy would take me up on a deal on "apparently" 9.25mm lift cams. Is it even possible to make use of that much lift?
Yes, please confirm gear and what rpm max power was at.
Got my car back yesterday after Autronic install and it made 185rwkw @ 14psi with the original GTS-R T3/4.
It made its max just over 6,000, is this normal?
They said there was a shitload more in it but my fuel system is out of puff.
I dont have an EBC but they said it was a good idea to get one as to hold 14psi steadily when the pedal is mashed it has to ramp up near 17psi then drop a psi or two and then it holds 14psi to redline.
Is this a normal occurence and will an EBC make it able to get up to and hold 14psi without going over?
I will post up the charts tonight for scrutineering!
My peak power of 202rwkw done with a highflowed R34 GTT turbo, if its anything compare to, is at 145kmh which is roughly around 6000rpm in 4th gear so, yeah it seems that the cams maybe the next restriction, although my power doesn't abruptly taper off, it just slowly starts curving downward...
Should be interesting to see how many trackdays this unknown RB20 manages to withstand with these kind of power levels :D
I might come down to the philip island day next month just to see it :D
:D
We always print our graphs with RPM on the bottom axis, and run in 4th gear. I don't understand why the kph reference, specially when you are trying to sort A/F. It is just anther calc to get back to the number you want....
Roys looks like something from Mt. Buller to me... we are going to run with full size exhaust next time out, so that should be interesting. Those p155y ones we run in Targa hurt the boost ramp something aweful.
Well done Roy, keep the faith
TT
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
