  • Replies 90
My Budget RB20DET-
Imported with HKS Super Dragger exhaust and K&N Big Mother air pod
Added TurboSmart boost controller - $250, dynoed @ 150rwkw
Added Dump Pipe - $300
Added Cold Air Induction - Free
Added RB25 Turbo - $350
Added Front-Mount - $500 (inc pipes, see http://www.skylinesaustralia.com/forums/sh...ead.php?t=47918)
Added additional Cold Air Induction - $50
Next I want to remap the ECU and then it's time to Dyno it again. Hopeing to be around 200rwkw for around $1K. Then that's it with RB20DET, move on before blowing the budget.
I don't think you can achieve a real 200rwkw with the small stock injectors, from the dyno i have experience with, the stock injectors will max out 180rwkw and by then the mixtures will be fairly lean at that.
My Rb20 with RB25 turbo, pod and 3" turbo back exhaust did only 130 rwkw with stock boost and everything else and 11.3 A/F ratio.
My RB20 did 150rwkw with 3" cat back exhaust, pod and turbo smart boost controller on the UAS dyno. What Dyno where you running it on? I've now got a FMIC, 3" dump pipe, CAI and an RB25 turbo, hasnt been dyno'ed with the latest mods yet however.
my 2c...which aint much :)
buy a rb30 bottom end from wreckers (mine cost $100 ;))
buy an rb25de head (mine cost $750)
do a std bottom end rebuild of the rb30 using same pistons, just hone, new rings and bearings ($850?)
bolt on head to block, drill tap tensioner, $30 timing belt, 2x rb30 tensioners ($80 ea)
how much so far?...using rb20 sump, manifolds, turbo (i am to start :)) water pump, rb20 oil pump....no costs here.
redrill engine mounts to lower engine, plug in rb20 sensors, mod front pipe.
done...turn key and watch the rb30 rumble for under 2k.
But as they say...the spending never stops once it starts....i wish i had kept to the plan above and watch people grin :)
Seriously though i had the same drama as you. Rb20 blew, and went the rb31. Never look back now :)
The rebuild costs your mentioning, is that doing it yourself? Would there be the need for any boring or machining?
Na stock injectors are good for 200-220rwkw. my 32 makes 190rwkw with stock injectors, pump, reg etc no worries.
I didn't think you could put the rb20 head onto the rb30 bottom end? Is what your saying just a miss type? Or can it really be done?
Using my Rb20 head would be a lot more easy, then looking for an rb25 head if I went that way with a motor build up.
Shoot about 10 years ago using an RB20 cylinder head on RB30's was common. It is a prick of a job, welding, redrilling machining etc. But the result was better than a SOHC cylinder head. Wouldn't even think of doing it now with RB25 cylinder head's being so common and RB26 top ends being almost affordable. :P
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
