What would be a good cost for the following car
R33 Series 1 GTS-T 1993
HNK Air Filter
Custom Spoiler
Brass Button Clucth
$2000 mags with Good Tyers
Standard Psi
Imported 6 Months Ago
105K Kms on the clock, who can trust that
Services between 5k - 8k kms
Major Belts Been Changed
Nice Interior
External Good, 1 Deep chip mark on rear left quater panel.
I'm looking at it atm, and what to know an estimate.
It would be really helpful
Cheers
https://www.sau.com.au/forums/topic/51193-cost-esitmate/
id say ~$17,000... not highly modified, possibly wound back (most are)
you should compare with examples from prestiege motorsport and maybe add 1-2k... find one that has been sold already recently matching your specs and compare... have you considerd importing one through an importer/broker?
https://www.sau.com.au/forums/topic/51193-cost-esitmate/#findComment-1014396
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
