For people who are wanting 200rwkw out of their "stockish" RB25DET heres something to consider. The dyno graphs below represent my car on 2 different dynos.
The first one was done December 03 on a 20degC day and made 153rwkw. Mods were:
* bleed valve @ 13psi
* Chipped stock R33 ECU
* Turbo back zorst (with crppy compliance cat)
* K&N panel filter
The sencond one was done June 04 on a 10 deg day and made 195rwkw.
For a bit of fun, lets see if you can tell me where the extra 42rwkw came from :)
https://www.sau.com.au/forums/topic/51206-want-200rwkw-out-of-a-stockish-r33/
come on dude, tell us.
I am on my way, just waiting for the tune now. The Powerfc on factory maps = 200km out of a tank.
I have -
Split Dump all the wat to the Cat
Hi Flow Cat
3"5 Exhaust, 4 inch Cannon
Front Mount Intercooler (stock plenum and BOV)
Partitioned Pod Filter
HKS Exhaust cam Pulley (not fitted yet)
Apexi Power FC + Hand Controller
Bleed Valve set at 10psi
18" 235 Treads
10% Mix of Toluene
Stock Turbo
Currently on about 150rwkw
Aiming for 200 - 210rwkw after the Tune. Apparently its very possible.
ones a dyno dynamics.. the other is the dynologics.. and lets guess that the dynodynamics might be in shootout mode correct? and maybe has some temp correction thrown in for good measure..
do i get some candy?
good pratical illustration though rigga :thumbsup:
That’s why people who trying and argue, that their car is faster because it puts out more power on a dyno. Is a load of bull. I have seen similar cases of a car on one dyno putting out 320hp and on a different dyno putting out 360hp. With nothing changed to the car.
If people say that their car is quicker because it puts out more power then mine I laugh. The argument stop on the ROAD!! You could have a car that does 700hp between 7 – 8k rpm and a 300hp car with a power range of 4 – 7k rpm I reckon the 300hp car would beat it over a ¼ mile. But the guy with the 700hp car can still claim that he’s is quicker because his car puts out 400hp more……. ???? Am I right in saying that ?
In other wirds RiggaP has shown a good example of that, Cheers Mate.
Gordy, Quite easy really:D Shootout mode dyno provide a list of details at the bottom of the screen, which records intake temps, ambient temps etc. Shootout mode 2003 has green writing down the bottom, but this is no longer current. Shootout mode 2004 has blue writing and has an '04 logo. These dyno can no longer be manipulated to provide higher readings.
Shootout mode dyno provide a list of details at the bottom of the screen, which records intake temps, ambient temps, yada, yada, yada
yup, I sort of know that :thumbsup: - but I was thinking maybe rigga had photoshopped these details out to make it another interesting point of discussion.. which it is already :)
I have noticed this over time the extra details on each printout. As part of their dyno "subscription" (purchase/rental/lease?) are the dyno operators required to get the new software with each update.. or is it optional?
Take it to a Shootout dyno to get consistant results.
Common, you know that's not true, I can get perfectly consistent results running a DD not in Shootout Mode. After all, I can set the parameters exactly the same as Shootout mode, the only difference is that they are locked and displayed. That does not mean that they are not set correctly. I believe that the Shootineers Code of Conduct is far more important to consistency than a piece of software.
Sorry, that might sound a bit harsh, but I am getting a bit tired of DD shoving Shootot mode down everybody's neck as if it's the be all and end all of dyno's. :thumbsup:
The cat.
Correct. This was the only mod done between dyno runs.
Also correct, and forms the very reason.
So heres my point; Dynos are a tuning tool. Anyone chasing a dyno figure is missing the point IMO. As my example has pointed out, you could achieve 150rwkw at one place then have another place "retune" the car and achieve 195 without effectively doing anything. I'm not sure anyone with half a twit is going to argue you can get 42rwkw by adding a high flow cat.
A dyno figure is not going to give you any idea how fast the car is going to be, and because of this, dont mean squat.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
