Also - what is the back seat leg room and head room like in
a) the sedan
B) the coupe.
(Is it as good or better than say a corolla?)
Thanks
PS Test drove a silvia and there was no room in the back.
Just wondering what an 89 or 90 model is worth these days, in reasonable nick and stock.  Is it close to 10k?  Or  a little more..
Is the sedan worth slightly less than the coupe?
Prices seem highly variable.  Just looking into getting one at the moment.
Thanks
Autos are much more common in the sedans, so if you are desperate, get an auto and add the $1500ish for a conversion. Watching recent prices, 89 or so seem to go for about $2-3k more for manual. The sedans currently seem to go for $1-2k less than the equivelent coupe (not as much demand), depending on where you get it.
You can just get one for around $10k for 89 fairly stock, but most dealers seem to charge a few $k over that. You're best bet is to import, while its still an option (if you can wait). Otherwise, you're battling the profit takers trying to get a few $ more than they bought it "just because they can".
Headroom in the back would probably be a concern in an r32. Going on my r33, 6ft people wouldn't fit comfortably in the backseat due to the head clearance for long periods. Doubt r32 is any better, if not worse considering they cars have less room overall. You could fit 2 people in the back seat though, but again, not much leg room.
Thanks Predator. Should be enough leg room right? I know wouldn't be heaps - but would it be like the silvias where you have to spread your legs if your over about 5ft 8. You could go to the snow or something with it but have breaks every couple of hours?
I'm getting prety keen now!
THanks
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
