Hi all,
I just bought myself an r32 gtst, and ive got a few questions:
Where is the ambient temperature sensor for the climate control - cos the one in my car keeps reading 45.9 degrees no matter how cold it is :thumbsup:, and how would i go about finding a replacement part if its stuffed.
What does it mean if the HICAS light comes on - It has come on only twice since ive had it, and only when i've been drving for extended periods over 100kmph eg going down the freeway. Does it mean that the rear-wheel steering is on, or buggered??
Thanks in advance
https://www.sau.com.au/forums/topic/51219-new-car-a-few-questions/
top of the dash in front of the passenger is the ambient temp sensor. Try a second hand one from the forums, or a wreckers. There is a dignostic mode for the climate control as well...
HICAS light can mean a number of things...powersteering fluid, or brake fluid could be low. Need a wheel alignment.
o a diagnostic check on the HICAS as well....should narrow down the problems at least to give you somewhere to start.
hicas light shows when the hicas isnt working
ive got the same problem but mines on all the time
apparently its really common with the r32s
and for the climate control sensor u can pick one up from "Wally" at Zimports 8244 7911
179 South Terrace, Wingfield
he has heaps of standard parts at very good prices too!
I'd get rid of the HICAS, replacement kits are available for around $100, and then take the bulb out of the dash
Mine used to play up all the time, so it has been replaced with a solid bar, and it works really well - feels much more stable and predictable :rofl:
My ambient temp sensor is at the front of the car.
It used to be located where the FMIC now is. I simply moved it to the side a little.
The sensor on the top of the dash on the passenger side is a sunload sensor.
The sensor on the right hand side of the center console right next to the gearshifter boot is the in car temp sensor I believe.
They all go hand in hand working out the temps, where to blow cool and warm air etc :D
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
