In my opinion drift is quite cool, although when some idiot claims he drifts and all he's doing are power slides out of corners it really pisses me off!!!
In a true drift the car is sideways entering a corner, not just exiting.
There is alot of hype about drift and it does have its anoying moments, although in times like those sit back and watch some d1 (the real stuf).
I personaly would rather take my car to a track day than drift day as I believe more wear occurs drifting in all areas and there is also a greater chance of me damaging my car as I don't know how to drift, although most of us skyline owners will surely be able to power slide nicely :P
take it easy
Mark
  • Replies 41
