omg thats horn!!!
man i almost feel like getting one now...
those rims are definately 18s.... way too big to be 17s... look at the rubber bands on em... or is it the car makes em look big
man that thing will haul ass once u get some pods on it and tune it for our shitty fuel :D
hmmmmmm mybe i should sell the ceffy :)
WOW...
Got some pods put on today (shitty ones because all the good ones are to big to fit in the limited space) anyway I took it for a REAL drive today (around my backstreets) and OMG does this thing farking scream and kick when it's wound up on boost. Have not stoped smiling all day... can't wait to get it on the dyno for a tune and atwkw reading, then down to Calder :D
dude, don't wind up the boost on the car until you've had a good tune. the car ran on high octane fuel all its life and is NOT used ot the poverty octane rating optimaxes at the pumps here.
Craig rang me n said he was gonna go over to check out the car and you were happy as, I asked him to let me know so I could cruise along too. Good to see you're happy with it. Now come to the meet at the whitehorse on tuesday and join the club beyotch!
PS how'd you jump the car at TOLL didn't you have a jumper pack with you?
Craig still has not come to check the car out yet... come round with him and check it out. Tell him to give me a call when he is ready because I want to get it complied ASAP. I only wound it up a bit... heheheh
I know I should wait for the tune but I was just looking at it all day sitting there. Sounds and feels like it is running solid (now I have the filters on). The clutch is VERY grindy but catches so shap and strong, that is what I need to get used to and the reason I stalled a gizilion times yesterday. My sister drove me down to Laverton and folowed me home...so she gave me the jump start (after running down to the shell and paying $35.00 for jumper leads) When turning onto the Westgate she made it through and I stalled (causing the block) I rang her on my mob and asked her to turn around and save me.
Tuesday @ Whithourse (no GTR) I will probably catch the farkin tram. Membership sign up OK that night?
apparently you're near Craig's office so if you want I can ask one of the boys to give you a lift in, or I can give you a lift if I'm there on the day.
As for membership signup, yeah we'll have forms on tuesday.
Will try to come over when Craig does.
The only thing I will be riding is my woman or my GTR... sorry to disapoint about any other type of ride...
If you boys who live close by want to go on a short squirt SAT or SUN I will be down for that.
It's not going to be that bad this weekrnd.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
