Hi guys,
I'm pretty new to all this modding stuff, and I'm planning on having a crack at puting on my Blitz turbo back exhaust this weekend. I have my brother and father telling me i'll need a hoist, but I never listen to them anyway. :(
Could people out there give me any suggestions/pointers as to how to go about this as I am not the most competant person with a socket wrench ;)
Cheers. :rofl:
well, its easy. We did it in about 30 mins on my Series II R33.
You'll need this tube of stuff that is pretty much a liquid gasket, put alot on and join the pipes. I have forgotten that name, but its good shit. Sets when the heat gets into it.
You'll need some bolt off, and a good socket set.
The ONLY hard part about doing this is the dump pipe. Getting it off the back of the turbo without snapping bolts. If you can do this, then it will be a walk in the park.
I suggest putting the car on a hoist, or over a pit, and going to work. I am lucky enough to have a mate that has a hoist, just to work on all of our cars, and that helps 500%.
Hoists are like a gift from god, when you have access to one easily.
But its not a hard job, just be prepared if you snap a bolt or something like that.
Also, its easy to just take the exhaust off from the back of the front pipe all in one piece. Then do the dump on its own
Cheers... sounds like I may be out of my depth, but I have nothing to lose so i'll give it a shot haha... where would I get this 'tube of stuff' from hehe?
I'll talk to the guys at autobarn (gf's friend) and i'l lsee if he has any stuff like it.
Anyone else got suggestions?
Just got mine done a few days ago. I had to do was slightly modify the turbo heat shield to fit the bigger dump pipe. The bigger problem was that my rear driveshaft was too close to the centre muffler I have on my exhaust, and it actually began rubbing. I simply solved that by putting a spacer in off the nearest exhaust hanger.
AUtobarn, Repco, etc should all have the gasket glue and items that you need.
  • 8 months later...
Be prepared to break some of the bolts holding the turbo and dump together. Your car is fairly old (93) so I'm sure some of the bolts have been rusted up. If you break a bolt, you have to drill out the remnants of the bolt and then tap new bolts in. There are six bolts in total.
Pete's method.
Take to exhaust shop, say "This should take about 30 minutes. How much is your labour per hour, oh $65 bucks, Sounds good. I'll wait."
Job done in 30 minutes, and if they snap a bolt, they have everything there to fix it.
BASS OUT
Pete's method.
BASS OUT
:werd:
Gasket goop is not really a great idea IMHO: your better off getting replacement gaskets. Do it right the first time. Besides, if you ever take it apart you'll be cursing yourself when you have to spend half and hour trying to clean hardened gasket goop crap off every joint.
Lucien.
Yes proper gaskets not gasket goo is the way to go :)
Yes gettin an exhaust shop to do it is also recommended for the reletively small outlay (do your knuckles a favour :) )
If you do decide to have a crack, and on your car it should'nt be to difficult, gewt under there now and spray a shit load of CRC on all bolts to be undone....it will make life a lot easier when you come to do it ;)
a hoist will make life easier. I did mine with the help of a friend with a hoist, and it took half a day (it should have been much simpler). The stock brackets that hold up the exhaust near the cat on a 32 were too small, and as the 3" has a larger ext. diameter (obviously) they wouldn't fit, and needed to be attacked with a grinder. the pain of trial and error until we got it right...
Also agree go out and get some real gaskets :)
always use new gaskets with gasket goo it's an added advantage thats what they do with space shuttles they cant be wrong
in saying that i do realise a car isn't a space shuttle i just like to use the techniques of the best mechanics in the world
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
