heres some pics i've taken of the wiring up of my engine to the r30 electrical syastem. if you have any questions leave a post and i'll put a more detailed write up for ya...
i'll update the pics when i get my digi camera back;
more detailed info posted 28/12/04 :rofl:
from the white/red wire at the back of the ignition a blue wire runs through to the ecu, a fuse was put at the end then it links/splices into a white wire with a black stripe and silver bands.. this white wire goes to the main relay (4 wires out of it, 1 orange, 2 white with black strip, 1 black with white strip). from the main relay the 2 white/black strip wires are connected together to make one wire....
from ignition the black/white stripe wire has a red wire spliced into it going to the ecu, it then is split into 2 fused wires,
the first fused wire goes to a thick white wire that goes to the fuel pump relay, with the fuel pump relay there are 4 wires, 1 orange, 1 white/purple stripe, 1 white/black stripe, 1 thick white wire...he has cut the thick white wire, the white/purple and the white/black wires.. the white only wire is connected to a wire running to the fuel pump its self... the white/black wire is extended to connect to a black/pink (pin 18) wire comming out of the ecu...the white/purple wire is spliced into the orange wire then that connects to the red wire running to the ignition, at that same point they are then connected to the other half of the thick white wire that dissapears into the firewall....
the second fused wire from the red wire goes to a black/red (pin 45) wire from the ecu
the pinout put numbers i refer to i got from www.rb20det.com
Edited by rsx84
Please excuse my ignorance but can't the Rbxx loom be spliced into the engine harness connector in the middle of the firewall ?
This would be my plan .
1) Mount RB computer in std location and feed loom from engine bay to ECU
and connect .
2) Plug RB loom plugs to engine sensors .
3) Cut plug off MR30 engine harness to graft onto RB loom to supply power
and signal to EFI and Fuel Pump relays .
Things I dont know about RB's are need speed sensor input ?
need map sensor as well ?
The FJ20's loom has a plug not too far from the main ECU interface . I'm not
sure what its for or if RB20DET looms are like this . Appart from The RB ECU and
loom to the firewall I would not expect to have to do any wiring inside the car .
Are my ideas valid or have I missed something ?
Cheers A .
the thing to know is that most of the rb loom is not needing to be touched just feed it through the hole in the fire wall. the trouble is the ignition connection to the ecu and control of the fuel pump, mostly external things to wire in. the only other thing is a sensor (temp i think) at the front of the block that is spliced into a fat clump of wires at the fire wall.
I don't really understand the ignition conection to computer problem , surely this is a plug that plugs into the ECU . The coil loom should plug via the ignitor to the engine harness to access the ECU . All the harness should need from the existing loom is power supply and signal access to ECU and FP relays . The FJ20 version also has the water tmp sender up the front of the engine and wired through the engine harness to the firewall connector . It also has signal feed to its unique idle air and EGR vacum pulse soleniods . The only other thing it has is FPR switched power to the cold start air regulator valve . All these things can be tapped into at the main engine harness connector on the firewall . All R30's I've seen have that connection and all engine controll wiring in a fuse/relay box next to the brake booster . What was in your car that required the alterations in the cabin area ?
Cheers A .
your starting to make it sound hard! OK all that was done in the cabin area was connection the ECU power to the ignition, what i'll do is over the next few days when the car comes back i'll take some more detailed pics the wiring in the cabin and replace the ones above. i'll look at the r30 wiring diagram and see what wires are what and post up a more detailed discription!
Fair enough , I just keep thinking that IGN PWR is available at the firewall connector . Mind you I have not got my hands on an R32 RB20 engine harness or wiring diagram to see how the R32's tic . I gather it all goes in with the MR30 X member and R32 brackets plus minor mods to gearbox mounts/tunnel hole . Is it a shit fight with the console ?
Don't mean to sound insulting, but if you are going to go to the hassle of swapping engines, whats to stop you going for an RB 25 DET instead of an RB 20 DET, given that from a legal viewpoint, the R30s were available with an L28? (Or was that just the 4 doors?) Mmmmmmmmm, more torque and 180+kW bog stock, standard.
machg
at the time i did the conversion i was able to get the rb20det installed and wired up, the r32 master cylinder and booster installed, the r32 radiator installed a new hybrid fmic and custom piping, new konis adj suspension all round, lowered king springs, whiteline sway bars front and rear, new dba slotted rotors and bendix comp X pads all round all for about $1000 dollars more then getting the rb25det, gearbox and loom just installed and wired.. it was just a dollars thing!! with good surrport systems on the rb20 and a rb25 turbo or vg30 180rwkw is not that hard to get....
have a look at the "dr30 with rb engine"??? thread in this section for more info on the other side of the install... :run:
Machg , mine will be an RB26/30 using a single turbo . My interest in the RB20 electrics is because its that loom I'll use with an Apexi PFC . RSX 84 does the R32 GTR/GTST booster go straight in or need mods ?
Thanks A .
P.S sorry earlier on , I gather by ignition you meant ignition on power supply . I re- read and I sounded a bit intense , cheers A .
Thanks  A .
Were you thinking of doing a detailed write up of the RB20DET wiring into HR30 ?
I'd really like to know the finer details ie speed input , tacho probs etc .
Thanks A .
could some one give me the scematic for the plug in the middle of the fire wall? ive installed an l24e into my hilux but need to get power to it and to the fuel pump....preffereable without trial and error blowing my computer up
if anyones looking heres a link to wiring diagrams for the r30
http://au.geocities.com/timsmr30/R30skyline.html
good info site but was never finished, shame don't know if he still has the r30 or not?
  • 2 months later...
Thanks  A .
just posted the info you wanted hope it helps, if it makes no sence ask more questions.....i have new pics but hotmail not working to retrive them???
booster goes straight on....
  • 1 year later...
first of all sorry for all the questions
What size fuses were used on the fused wires?10A?
Did you use the RB20 alloy engine mounts between the block and the rubber mounts?
In the 2 photos of engine bay, is the white wire the same wire from water sensor?? to the old R30 loom on fire wall, if so which wire does it splice into?
"The white only wire is connected to a wire running to the fuel pump itself"
Where on the fuel pump is this wire connected???
if ya have anymore pics of the wiring or any part of the conversion they would be much appreciated, or any tips/tricks or any problems or mods needed
also what is the pic of the plugs hanging down by the accelerator pedal showing??im not sure?
Thanks
D
Edited by horses
  • 3 weeks later...
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
