hey peeps
ive just done a few searches and i cant find the info im after, so i thought id ask.
im trying to hook up my air fuel gauge and i dont know which is the signal wire on the o2 sensor. the autometer instructions say i have to splice the wire after the clamp thing but is that nessecary? the wire that i spliced after the clamp adapter thing is a thick wire with copper colour wire in the middle, silver wire around it then the clear sort of heat shrink around it. is this the right wire?
if anyone can give me any hints id appreciate it heaps!!!!
https://www.sau.com.au/forums/topic/51253-air-feul-ratio-gauge/
Hi i fitted one of those to my car but it got stolen with the rest of my gauges anyway the wire i had it joint to was the middle wire on the plug it was a brown wire if you peel back the black stuff that covers the wires it should be a bit thicker than the other two (not the wires on the sensor) hope that helps
yep sic thats the wire i am trying to use, but it has like 2 different colour wires on the inside, like silver and copper, so i just join it to both then hey?
also does the gauge actuall start to work right away or does the car have to heat up 1st, casue ive hooked it all up and the gauge didnt work???
thanks for the help jason
just one last question- i have plugged everything in, and when its just the + and - wire in, there is a green led lit on the last point closest to the end of the rich section. then when i plug in the o2 sensor wire the screen goes blank, even wen the car is on. do i have to be driving for the thing to work or have i done sumthin wrong?
ok i got it all hooked up now, but wats it supposed to look like, about 4 leds light up at a time going up and down the face wen u rev it and on idle sumtimes, it just hits rich. but at night wen i turn the lights on, it read a couple of leds short, is this supposed to happen?
let me know if u think it is functioninf wrong.......thanks for the help so far:)
i tihnk there should only be one led on at a time, considering its measuring a ratio, not a range of ratios, the led will move rapidly though
the gauge should work alll the time, driving idling, warming up etc.... i believe the oxy sensor doesn't work effectively till its warm and hence the ecu ignores the signal from it when u cold start, but once warm u should get semi accurate readings regardless of wheter u r drivign / idling / just starting
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
