geez, thats might mean that sumthin is wrong with my guage or the way i hooked it up cuase its shown more thne 1 led at a time, and sumtimes it stops, then when u hit the accelerator it will work again???
sounds the same as mine, usaually have 3 leds lit up.. when you are at constant throttle it'll pulse from 1 red to the end of stoich. thats normal..
however read the manual, if its auto meter then the stich level is actually around 12:1 from memory, bit higher than is optimal!
If the aftermarket gauge you have uses the standard lambda sensor, then there are a few things that you need to know first. The standard lambda sensor (in all cars not just Skylines) is what I call slow and narrow (S&N). They react slowly to changes in A/F ratios and only measure over a very narrow band of A/F ratios. So not only can the car go super lean very quickly and the read out not show it (the slow part), it can also be so lean that it is outside the measuring range (the narrow bit). On the dyno we use a fast and wide (F&W) lambda sensor, obviously this responds quickly to changes in the A/F ratio and it measures over a very wide range of A/F ratios. As usual, cost is the issue here, a F&W lambda sensor costs around 10 times as much as a S&W lambda sensor.
When you start your car up from cold it runs rich, so rich that the standard lambda sensor does not measure that much richness, the gauge (relying on the lambda sensor) will simply go full rich or look like nothing is happening. As the car warms up, obviously it no longer requires a rich mixture to run, so you will get some reaction from the gauge. But it will move around a lot, because it is only measuring over a very small range of A/F ratios, like 11.7, 11.8, 11.9 12.0 etc.
At light throttle cruise (no boost) you see lambdas around 14 or 15, some gauges have trouble showing this normal (lean) situation. A full throttle and climbing rpm, the lambda sensor will have big trouble keeping up with the changes, so treat the results with a lot of suspicion. At idle they normally work pretty well, as things happen slowly and the lambda is within their sensing range.
Bottom line, if you want a useable A/F ratio gauge you really need to start with a F&W lambda sensor and then buy a gauge that can read it.
Hope that helps :D
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
