*TRUST T78 COMPLETE KIT POLISHED perfect condition $4500.
*TRUST CAM GEARS NEW IN BOX $400.
*RB26 NO TURBO with BOX AND NOW BUTTON CLUTCH HEAR RUNNING $4500.
*VOLK RACING DEEP DISH 17S GTR OFFSET NO SPACERS REQUIRED!
with rubber 255/40 LAST SET LEFT $1400.
*700cc SARD injectors NEW IN BOX $650. sold!
*700HP SARD IN TANK PUMP MNTH OLD IN BOX $400.
*GREDDY PROFEC B ELECTRONIC BOOST CONTROLLER WITH TIMER $350.SOLD
*TORQUE SPLIT CONTROLLER / GFORCE METER $sold!
*STAINLESS 4inch cat bak jap style $650.
*POWER FC WITH CONT NEW IN BOX $1000.sold!
*GAB COILOVERS HIGHT AND DAMPER X4 $700. sold!
*STD R32 GTR WING $200.
*INTERIER MAKE OFFERS?
*DAMAGED R32 93 MODEL GTR SHELL WITH LONG REGO NOT ON REVS! serious
offers considered.
CALL ME IF YOUR SERIOUS! 0404 8484 81 :uzi::bonk: [email protected]
https://www.sau.com.au/forums/topic/51265-gtr-power-parts-very-cheap/
condition of t78 kit[/quote
T78 is big and POLISHED
allways filtered so blades are perfect
its a kit so you get everything
*turbo
*stainless stell tuned length manifold
*exhaust to the punched cat :wassup:
*BIG wastgate
*pipe from turbo mouth to filters
*braided oil lines
everytrhing is TRUST not garret shit!
if your keen i can send pics.
What brand are the injectors?
Can you please send pics of the exhaust to [email protected]
Its one piece s/s and no bolts the brand is fujitsubu 4inch with 2 muffs and is pretty quit until you hit big revs dont have a pic at the moment
No to what????
Not being negotiable or No to sending them COD.[/QUOT
no to dropping price, i paid 500 i only want 400.
id rather keep them, there new and very shiny!
deposit it into my acc only way im sending my parts.
  • 1 year later...
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
