Alright about 2 hours ago i was drivin down the highway..everything was fine as usual. Then as i wnet to rev it a bit it got to about 3grand then just wouldn't go anymore. The engine sort of shuddered, and the car shook but i couldn't rev it past 3grand in any gear. Then as i decided to drive home it got worse...couldn't rev it past 2 grand. Then as i stopped at the lights the car stalled..started her up again and unless i give it some gas it would just stall. Got home...looked for air leaks etc..nothing i could find. Started her up again...everyithing was fine, perfect.
Took it out for a bit of a drivve and after 10-15 minutes it started doin the same thing...would let me rev that much..the engine shuddering all the time i put my foot on the gas slightly. Then when i go to stop or slow down it just stalls.
Anyone know anything that could be the cause of this.
IF this helps my car is running very rich atm...like i get 260 to a tank. My mods a full 3" zorst and airfilter runnin stock boost
ThnX
https://www.sau.com.au/forums/topic/51267-problem-with-rb25detplease-help/
limp home mode is in autos only i believe , thats where it goes into shit mode becuase somethings ****ed , so after a certain time like 10 mins it is starting to happen hmm , well if its not happening until the engine warms up , then maybe there is ur problem somewere , check fuel pump . filter , thats all i can think of
limp home mode:
the ecu thinks there is something wrong, such as sensors failing and therefore assumes stuff is bad and wont rev past 2500 rpm (ish) its in both auto and manual, the most common cause of limp home mode is dead or faulty air flow meter, the ecu doesnt know how much air is coming therefore it assumes its only a little to prevent running dangerous lean mixtures etc..
check all piping, intercooler, plenum, throttle body, etc for leaks
Have u been playing arround under ur bonnet.Have a look to see if your air flow meter has any loose connectors or worn n shagged cables.A dodgey signal to the computer could be it.
Also check your that you are getting proper spark.It could be that your coil if shafted.injector cables and connectors wouldnt hurt either.
Also check your that you are getting proper spark.It could be that your coil or leads are shafted.injector cables and connectors wouldnt hurt either.
hey guys
just lettin u know today i got my hands on another series2 afm that had done low kays. Put it in my car not long agoand i tell ya what it is the best 100bucks i have spent...well so far. Problem is gone, engine feels sooo much better than it did even before the problem. Hopefully it will solve some of my running rich issues..
Will keep ya updated if something goes wrong.. thanx for ur help
Simon
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
