74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
oh crap I should have read the title...anyway I can't be bothered going to the DR30 one at the moment. I asked the wife and my sister and they both said that the DR was a muscle car...I think the HR is softer myself...whether its a GT or not I don't know...never thought about it, only know they have an rb20 in 'em (don't they?).
I reckon they're a GT, but I can't vote now cause I voted muscle car cause I never read it and I'm a dumb arse! :P
  • Replies 49
definately GT due to the weight. The gts-r looks aggressive and all but is heavy due to the HICAS 4 wheel steering system. I absolutely love HR30 rs-x's also. The power to weight ratio is amazing. Matt's car is the bomb!!!!!!!! you can make the 4dr versions of the r31 as aggressive as the hr31's. In a few months, mine will be a mechanical testiment hopefully
there are hr31 gts 4doors too:)
The HR is pretty weak to start with...takes a bit of work to make it as fun to drive as the dr but much prefer the rb over the fj personally, but would take a good dr30 over the hr31.
Answer, none of the above.
I was wondering how long it would take before someone piped up with that comment.
Gimme a Passage over a coupe any day.
Coupes just aren't pimp enough.
  • 4 months later...
I would say GT from the poll, but in actuality, Sporting Sedan (yeah, IMO the coupe can be called a sedan anyway, 2 door sedan) would be my description.
The GTS-R is a homologation special.
Ive owned an ausie R31 and have a HR31 GTS-X....stock the HR are fairly weak but get some mods happening and they are an angry engine....Im going with Muscle Car....just cous for the curves on the car are so aggressive compared to later skyrines - thats my personal thoughts
After having driven my brothers mate's HR31 i do not rate them!! They are a B O A T!!!
I definatly feel that they are more of a GT style of car then a sports car, kinda like how the later skylines i feel are classed.......Long range cruisers more then sprts cars
hell yeah! im gonna do that to mine when i get it, whether a passage or a local- dark, low, sweet sweet rims. mmm. if i wanted a coupe id getta r33 or something. which i would still prefer a four door variant...
Yeah.. I admit I love both the HR31's .. but to be honest, if it came down to a choice between R32 or R33 and HR31, I'd take the R32 all the time.
I have a Passage and R32, and they both have silvertops...the Passage is over 200kg heavier than the 32, and there is a big difference in the handling - it is nowhere near as nimble or point and shoot. The R32 feels like a sports car when you sit in it, and drive it - whereas the HR31's have a pretty different feel.
The Passage is very cool in it's own right, but more of a cruiser for the streets, not the track or the mountains. Might have good potential for drift though.
  • 4 weeks later...
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
