My car is makn me crazy!!!
Driver
 Share
  • Replies 54
Oh I remember that one, the one with the plastic on top right?
Damn I should've bought it :D, driver want a short shifter? :D I'm getting one keke :) btw what do you get out of full tank?
my car is running like crap 340 km full tank ...
heh yea i already 1/2 broke my box! grr
nah i cant even afford lunch atm - heh
when i get paid next ill fill it up - supposbly there is a button on the dash, which ive never seen be4 that u can record how far uve gone.
i rekn my car will do about 200+ km per tank
you guys must drive pretty hard :D
i get at least 450km a tank each time and thats only when the fuel light starts coming on.
Driver whered you get that cover for your front plate?
OK sorry driver i wish i had read this before hand. I had the exact same prob when i 1st got my line..... upped the boost and had the same probs... an EF Falcon beat me! and as much as Paul doesn't beleive me i am an ok driver .... it WAS definately something wrong with my car..
boost wound up to 11 psi and air fuel ratios were shot... similar mods to you... we then wound boost back down to the standard 7 psi and all was ok!
The ANSWER = APEXI SAFC. (if you can't afford a complete ecu at moment)
I am not a mechanic and i don't know EVRYTHING about cars... but i am quite certain your air fuel ratios would be shot.... an SAFC would fix this plus give you about 15 - 20 rwhp!! YAY!!
Basically what sydney kid said!
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
