i know of a dude who has rb26 in a vl, dont know whether the attesa system is also operating in it.
but to put a GTR badge on a vl, thats just terrible, some people are just disturbed i guess. Next to be put on may be an 'xr6 turbo' badge for that bloke.
There's one VL out there with an RB26 and all the ATTESSA running gear.
Even though... it's still not a GT-R!
T.
A VL with RB26 and GTR running gear I think can wear the " Almighty GT-R " badge..
